Heating settings
I have had a similar issue as you in both my '07 and '10 XKR's. The '07 was worse and it mainly happened in the colder months but about half way through my 4.5 mile journey to work the cabin would become uncomfortably warm for a minute or two before the system finally switched over to a cooler bias.
I don't see the issue in the summer, presumably because heat isn't required, even first thing in the morning.
You do seem to run your XK on quite a high temperature though. I used to leave my '07 on 19.5 deg C to try and counter the effect and my '10 is usually on 20 or 20.5.
Re the temperatures: this probably also depends a lot on personal preferences and what you usually wear. Ie. on weekends in winter I wear maybe a high neck pullover and jeans. Then 23 degrees is the preferred setting I like in the XK. When I drive to the office in a busses shirt, then it will raher be 24 degrees.
I tend to prefer it rather warm then cold in the car cabin in winter.
Br
ter
jimmy
01-27-2010 09:00 AM
