Help with ACM, disconnected
2007 XK
A while back somehow the material under the glove box started falling down. After that I had random wires and connectors falling. I eventually just pulled the material out and then yesterday I noticed a box laying on the floorboard. I haven't had BT and my usb connection hasn't worked in forever so I'm guessing the connections to the ACM were pulled out. I thought I figured it out but it doesn't seem to have any power. Does anyone have a "how to" on the connections for the ACM? I'm guessing the usb plugs into it and have that done. There is also a connector free that looks like an old school mouse connections. There is a spot in the ACM but it stays pretty loose even after it's plugged in. Just wondering if the ACM gets it's power from the head unit or if there is another connection I'm missing.
Thank you,
Rob
Thank you,
Rob
