Help! All the Dash Lights Lit Up
Was a code reader plugged into the OBDII port when you started the engine? That can make your dashboard go bonkers.
A low battery can cause that, too. Before you try to start your car, turn the headlights on high beams. If it won't start, your battery is low and needs to be charged. Use a 10A charger, not a battery maintainer or trickle charger.
Cee Jay (06-12-2021)
Stuart S (06-13-2021)
