Help - Bonnet Open Error on Dash - Resolved
Old 09-09-2012 | 10:51 AM
mosesbotbol's Avatar
Question Help - Bonnet Open Error on Dash - Resolved
I am getting a Bonnet Open error on the communication center display. I have open and closed the bonnet several times and feel pretty confident that it is indeed actually closed. The warning appeared after I washed the car.
How do I reset or fix it?
jobrien53 (03-17-2014)
Old 09-09-2012 | 11:15 AM
Big Grey Cat's Avatar
Close the bonnet, then get inside the car. Now slightly pull back on the bonnet opening lever. Don't pull enough to open the bonnet again. You may have to do this a couple of times. This puts the open hood message off on mine when it comes on occasionally. Just watch to see if the warning goes off while your doing it.
mosesbotbol (09-09-2012)
Old 09-09-2012 | 11:18 AM
jimbov8's Avatar
Also check the engine compatment security switch situated at the right hand hood latch, you may have got some water in it.
Old 09-09-2012 | 11:20 AM
steveinfrance's Avatar
+1 on jimbov8's comment.
Maybe a hair dryer/hot air gun on the switch?
Old 09-09-2012 | 03:46 PM
Rey's Avatar
Rey
Generally, on almost any modern auto you can reset any false codes or warnings by any of five different methods. But, if the code reappears and/or does not reset then it is a true fault which must be addressed.
1. Most auto supply stores (i.e. AutoZone) have OBD readers which can erase false codes. Often there is no charge for this service.
2. Disconnect your car's battery's leads and let the car sit for as long as 24 hours. The memory capacitors in the car's computer will discharge, resetting the false code to "normal". BUT if the code reappears you have a genuine problem.
3. Fix #2 process can be shortened by disconnecting battery leads/cables; and holding the cables (detached from the battery, of course) together for a few minutes.
4. Often, but not always, a false code will reset by itself after a certain number of restarts.
5. Take you car to your friendly Jaguar dealer.
Old 09-09-2012 | 10:42 PM
This fixed it, thanks!
Old 10-23-2012 | 11:42 AM
Well...
Every time I open the bonnet, the error comes back in the dash. We tested pushing down on the hood on the driver's side when pushed, the error goes away. I am ordering the hood sensor for that side. $138 and dealer does not stock. Indy wasn't sure how long it'll take, but I don't think it will take long.
While the car is there, I am removing the Hella Duo Tone horns. Wasn't as thrilled with them as I thought I'd be. I am replacing them with a trumpet horn kit I used on my S2000. This is a cool kit that has the compressor and horns built into one unit. No hoses.
Old 10-05-2023 | 11:20 AM
cmotson's Avatar
Default Bonnet open warning
Bonnet Open warning. I've tried all the tricks listed in some of the posts, including lightly pulling on the release latch, and jumping the connector the car side not the switch side. Still get the indicator. Any more suggestions?
99xk8guy
06-05-2023 07:28 AM
Shawn Svacha
02-06-2022 05:53 PM
1964Daimler
09-09-2015 12:28 PM
XCrossWindsX
09-05-2015 11:58 PM
Quick Reply: Help - Bonnet Open Error on Dash - Resolved
