Help changing daytime running light
Not sure what your having an issue with? Once you pull the headlight assembly, you need to open up the the side domed cap to gain access to bulbs. Depending on what bulb your replacing you may need to remove other bulbs to get to the most inner bulb... Here is a link to when I did my led conversion, read through it an see if it helps you...
https://www.jaguarforums.com/forum/x...pgrade-195058/
Let's clarify something here. The OP is not referring to the DRL bulb, but to the cornering light bulb in the Active light system (meaning the optional swivelling main light system). This cornering light only illuminates when the wheels are turned, and the other lights are on (the turn signal might also be involved in activating the cornering lamp...not certain, though), so this makes me wonder if there is in fact any problem with the bulb...or have I got this completely wrong and misunderstood? (Not at all impossible...still working on my first cup of coffee...).
User 070620
10-14-2019 05:17 AM
User 070620
03-13-2014 07:55 PM
stepdot
08-21-2013 07:44 AM
