Help!!! Cold winter Jag issues
So my 2011 jaguar is reading codes, P0016, P0018, P0175, P0172, P0316, and my cruise control P0590.
My car is starting but then after a couple seconds it sputter's and dies. It has been very cold here and the battery was zapped. I charged it up and it still doing it.
May have influence?
It’s been -10 degrees to 30 degrees for a couple months now.
I do have a small coolant leak but it’s very minimal.
Just replace the brakes on it.
It needs alignment.
Any advise on this?
May have influence?
It needs alignment.
Any advise on this?
One thing to note, although you might want to reject it: those codes and the cruise control warning, coupled with your “zapped” battery lead to what should be considered first as the culprit: the battery. How old is the battery? The fact that you charged it does not mean that it will hold voltage under the starting load. Low battery voltage produces all sorts, any sort, of random symptom including codes thrown for the most unlikely things
Do you keep your battery on a battery minder like the CTEK? Use of those units virtually eliminates these issues.
If you put a new battery in, you must ensure that it is at full charge *before* installation. Do not rely on a clerk telling you that it is at full charge because new batteries are never at full charge off the shelf.
Boji Mike (02-28-2022)
KeremArsan
05-09-2018 11:56 AM
