Help! Electrical Issues (CANBUS?) - Multiple Warning Lights
your reading is ok. 60 or so ohms means a possible bad resistor or module with everything plugged in. On my car the resistors are in the abs module and the ecm. Yours might be differen. Unplug a module and then check the two pins again. When you get 60 ohms or so you have found one. It is best to disconnect the neg terminal at the battery when disconnecting or connecting a module. It will not affect your ohms test. The module should not be awake in any way when messing with plugging or unplugging it. I just went through a similar canbus issue. Google up canbus diagnostics and you will find some very helpful info on troubleshooting
I have corrected a mistake, the reading taken was around 105 Ohms.
you are right the 60 ohms is good between the pins 6 and 14....i got backwards.....had to read thru the article again.....sorry.....if you are getting 105 ohms with everything plugged in then you do have a problem somewhere...there are a few other multimeter tests you can do at the dlc link also....the instrument cluster is the gateway for all network comms except d2b i believe....you can still do the unplug one module and check ohms to narrow things down a bit
Gillsy (01-03-2024)
Fixed?! (Instrument cluster at fault)
Just got the car back after a lengthy stint at the garage.
The fault is (hopefully) fixed. I had suspected the instrument cluster as a likely suspect as I was experiencing high resistance on the can circuit. The instrument cluster was sent away for inspection/repair, and they found a few dry solder joints on the PCB. The brake switch was also changed to rule this out.
Time will tell if everything is sorted.
The following 5 users liked this post by Gillsy:
guy (03-06-2024),
kj07xk (03-02-2024),
Prettykitty (03-06-2024),
ralphwg (03-03-2024),
V7Sport (03-03-2024)
Aarcuda
07-15-2023 12:34 PM
tim2211
01-10-2023 06:15 AM
trc
05-20-2016 11:19 PM
nemean
07-24-2015 03:27 PM
