We might be able to contribute if you took screenshots at each stage of the process you're following. I read your post in another thread indicating you followed Cambo's directions so it would be helpful to show what you're doing.
Also, could be wrong but that looks like a VCM 2, which are not comparable with Jaguars. Or it's a GNA600+VCM, which are comparable with Ford, Mazda, Honda, LR but not Jaguar that I can find.
"Ford, Lincoln, Mercury" right there on the label.
Get a DA Dongle, the Jaguar Certified module that's about the same basic design you have there. J2534 is the part number. About a hunnerd bucks. Mongoose cables are upwards of $300. MAngoose cables will may fry your ****.
Thank's for yours responses. But i use my VCM on only jaguar et i've no problem.
I've initialize TPMS module on my xkr, after fault light, and it's ok now.
I can get DTC too.
I don't understand where is the problem.
I go to post pictures of my tests.
Yep, understood. I'd like to see a snapshot of your vehicle shown in the frames from the 22 second interval of the video through the 33 second point. Confirm it's actually reading your VIN and identifying your vehicle.
I could be wrong but I still don't think that VCM is designed for your car and I think that's the issue. Show video of your car please. Or show snapshots - the entire PC screen please including the upper right.
As far as the process, yes, if you're following the process in the video, only selecting Audio Input Aux instead of service interval, it is the correct process.
Without video or pics, I'm not sure anyone can help you.
Yes is read my vin.
U102768 : no i don't see your sreen.
Top right corner sreen :
VCM
When i've "Run" TPMS module i can clear the fault light with the same process.
My car diag :
When i've connected my VCM the system have make un update to VCM.
Other picture :
Today i try to test.
Thank's.
Good day.
