Help me identify the part - XK 4.2 NA - 2007
Old 04-03-2024, 04:00 AM
neven.gordic's Avatar
Default Help me identify the part - XK 4.2 NA - 2007
Hello forum,
Last week I bought an XK 4.2 from 2007 and today I got it on the lift at my friends place and we noticed that I have a small oil leak coming from this part:
I guess this is an engine oil cooler but it seems that someone bypassed it. (I guess it was leaking coolant into oil system)
Can someone please help me identify the part number so I can try to order a replacement unit.
Thank you!
Old 04-03-2024, 08:28 AM
kj07xk's Avatar
Received 1,975 Likes on 1,326 Posts
Old 04-03-2024, 08:34 AM
kj07xk's Avatar
Sorry, couldn’t help it.
I ordered a spare a few years ago and this was the part number listed in the eBay ad:
6W83-6A642-AA
Old 04-03-2024, 08:39 AM
neilr's Avatar
neven.gordic (04-04-2024)
kj07xk's Avatar
Here’s the part listed on our forum sponsor’s web site:
Old 04-03-2024, 01:22 PM
GGG is offline
Received 16,851 Likes on 12,186 Posts
Originally Posted by neven.gordic
...... (I guess it was leaking coolant into oil system) .....
Not necessarily leaking. The oil filter is awkward to remove without the correct fluted key and a PO could have done this to make it more accessible. Given the cost of a replacement cooler and that it's showing as out of stock at Jaguar, I'd reconnect it and see what happens. Just run it up to temperature and not embark on a cross country tour, of course.
Old 04-04-2024, 02:07 AM
Thanks a lot for the answers provided.
When I search for 6W83-6A642-AA it gives me a Ford part which is priced at around 80 euro. The one from Barratt is priced at 485 euro.
They both look the same on the pictures tho. Will give it a shot with the Ford part since it a lot cheaper.
I managed to find a mention of this in the service record from last year. Car was at the official Jaguar Land Rover dealership here in UAE and they made this bypass since the replacement part was not available at that time. Dodgy repair by official service center if you ask me.
In order to change this part out, I need to drain both oil and coolant, right?
Old 04-04-2024, 03:45 AM
GGG is offline
..... When I search for 6W83-6A642-AA it gives me a Ford part which is priced at around 80 euro. The one from Barratt is priced at 485 euro.
They both look the same on the pictures tho. Will give it a shot with the Ford part since it a lot cheaper. .....
I agree the images look the same so that would be my approach too. Ford parts specialists are showing it as discontinued but that same number 6W83-6A642-AA led to this ebay listing:
https://www.ebay.co.uk/itm/163800454981
Worth investigating.
An oil change is a given as you will be disconnecting the filter. Coolant loss can probably be limited by temporarily blanking the hoses but I'd take the opportunity to do a flush and refill.
The following 2 users liked this post by GGG:
Arminius (04-13-2024), neven.gordic (04-04-2024)
Old 04-11-2024, 07:47 PM
JaggyBoii's Avatar
Earlier this year car had an oil leak. I thought it was a failed gasket within the oil filter, or a coolant hose. But it turned out to be the oil cooler housing, once ordered part took approx. 8-10 days to arrive. Billet not plastic, there are two types. No leaks since (knock on wood)
neven.gordic (05-22-2024)
Old 06-26-2024, 04:47 AM
Hello forum
Soon it will be time to change oil on my XK and I would like to use that opportunity to replace the leaky oil cooler.
I managed to find an original part on ebay under this code: AJ810959 but they are asking 500$ for it.
I also managed to find a Ford part under this code: 2C2Z6A642CC for 80$
As far as I am concern they both look exactly the same. What do you guys think? Will this Ford part work in this application?
Old 06-26-2024, 04:52 AM
Not sure if I should go with the Ford branded part that I found on ebay or the Land Rover one that GGG suggested in this post under code: 4526544
Old 06-26-2024, 09:34 AM
kj07xk's Avatar
The Ford part appears just a bit smaller than the Jag part, in that the number of ribs on the cooler is less. I have an extra cooler that I bought from a breaker years ago off a 4.2L XK (for a project that I’m finally getting back to), and it has the same number of ribs as the advertised Jag cooler.
neven.gordic (06-26-2024)
Old 06-26-2024, 11:48 AM
Yeah, you are right. There is a difference in size. Search continues....
Btw my current engine oil temp sits at around 98-102C in 40-45C weather. Is that considered to be normal/ok?
Old 06-26-2024, 11:54 AM
kj07xk's Avatar
Normal for coolant, don’t know about oil temp (that’s what part of my long delayed project entails).
Old 07-03-2024, 03:04 AM
Engine oil cooler finally replaced!
At the end I went with Sortech unit that was 140$. Same size, same number of fins as the original one.
We changed the part without needing to drain the engine oil. We just topped it up with 200-300ml of fresh oil and some coolant at the end.
The following 3 users liked this post by neven.gordic:
kj07xk (07-03-2024), panthera999 (07-10-2024), steve_k_xk (07-06-2024)
Old 07-11-2024, 09:45 AM
Kovvaks's Avatar
Default radiator
Переводчик
Добрый день, можете пожалуйста предоставить дополнительную информацию по этой запасной части?
По какой-то причине я не могу ее найти
Old 07-11-2024, 10:07 AM
bydand's Avatar
Originally Posted by Kovvaks
Переводчик
Facebook Post
Chinese Auto parts manufacturer, for Jaguar, LR, BMW and MB etc.
No idea who they supply too,
Old Yesterday, 04:04 AM
Kovvaks's Avatar
Can you tell me where you bought it?or
Old Yesterday, 04:15 AM
bydand's Avatar
Have to wait until Even.Goric comes back.
Why not get the Ford one, or KIA/Hyundai .https://www.ebay.com/p/1711147213?iid=176431788875
Ford OEM Engine Oil Cooler 2C2Z6A642CC Image 6
5.03 product ratings
Price:
$47.99
Free shipping
Est. delivery Mon, Jul 29 - Wed, Jul 31Estimated delivery Mon, Jul 29 - Wed, Jul 31
Returns:
30 days returns. Buyer pays for return shipping.
Condition:
NewNew
NEW Diesel Fuel Cooler for 08-10 Ford Power Stroke 6.4L Diesel Fuel Cooler. NEW Oil Cooler for 2003-2020 Ford Econoline VAN 5.4L 4.6L 2C2Z6A642CC. New 1.6L Turbo Engine Oil Cooler 26410-2B740 For 2014-2020 Hyundai Kia OEM.
Old Yesterday, 04:17 AM
Kovvaks's Avatar
Translator Will it really fit?
Quick Reply: Help me identify the part - XK 4.2 NA - 2007
