Help with P2096 code
Good morning guys, I recently replaced my CATS with higher flowing 200 cell ones from Velocity AP. It triggered the CEL and about a week after I had an ECU tune to address the CEL. I suspected that the position of the downstream Oxygen sensor (2-3 inches from CAT) was the culprit. I had the muffler shop re-locate the sensor to rear portion of the CAT. Codes went away but returned with a P2096-Post Catalyst fuel trim system too lean, Bank 1. The only changes I've made was the replacement of the CATS. I am about to replace the 2 downstream O2 sensors but I don't think that is the issue. Any ideas? I really appreciate any help/ideas
How many miles have you put on it since relocating the sensor? How many since new CATs? Did you unplug the battery both times?
There is restart procedure that I only recently discovered that says you have to let the car get up to temp during initial idle so it can re-learn idle values. Then you have to go through a few drive cycles for all the other stuff.
After I installed new CATS, I cleared my codes, took a 200 mile trip and they never came back.
badicedog (07-07-2019)
Fuel trims will not resett with clearing codes but only by battery disconnect. I would say either your rear sensors are bad, wiring or the location of the sensors is the issue . Definetly do battery disconect to restart the fuel trims
And just to be on the safe side if you did any work to your air filter or anything under the hood I would double check to make sure you don't have any vacuum leaks and everything is sealed tightly. Now I Just remembered I had one XKR here that had codes for too lean and it turned out to be rubber connector to the throttle body that was leaking vaccuum.
Also use obd2 adaptor to monitor your long term fuel trims on both banks at idle and at different loads, this will tell you if your actually running lean. When you were at my place your fuel trims were normal
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
