Help! rear sidemarker light
The bride had me do a few things before getting back to a hard reset. I had noticed last week that the rear 'vert window was once again separating just a tad. When I purchased it 2 years ago the window was separated badly and I made repairs with the help of some good write ups on this forum. I thought while I was completing her honey-do list I would let her idle with the A/C blasting, lights and hazards on in the hopes that if anything were moist from all the rain and humidity lately it would dry it out. Walked out, gave her a rev just to turn my slight frown into a smile, turned everything off and everything did turn off, including the pesky rear sidemarker. Hard reset not performed, Moisture on a board somewhere????
Well, the light is out for more than 36 hrs... Have not done a hard reset. The only thing I can add is that beyond the moisture theory, I had a low fuel warning and low washer fluid warning while this was going on. Also I had not moved the car. Yesterday I once again installed the tail light assy. topped everything off and went for a drive with the top down.
ralphwg (08-31-2019)
grunter
12-26-2009 03:49 AM
