HELP: Is there a simple A2DP Bluetooth Music stream solution ?
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Checked the threads and seems to be a lot of conjecture on the issue.
I a have a 2010 XKR and using an iPhone 5. Would like to stream music via Bluetooth such as pandora etc.
Any constructive advise would be appreciated.
Thanks in advance.
Thanks in advance.
Spotted this on eBay:
Bluetooth Handsfree Car Kit iPod A2DP Music Streaming Device for Jaguar XKR | eBay
Might be a useful starting point
XKGuy (06-04-2013)
The following 2 users liked this post by russduka:
bigdhenderson (05-05-2014),
Del Boy (05-21-2014)
I bought a couple Blackberry Stereo gateways. One for the home, the other for the car.... Haven't tried the Jag yet, as I still have to install the Audio Control Module as well.
Should be simple to try if you already have the ACM (not standard on my 2007....)
Vince
Vince
Vince
Vince
My 2009 XKR only had the standard ipod connection so I landed up getting a little device called Tune2Air
Tune2Air WMA1000 Bluetooth Music Receiver, Support Airplay, Audi-A2DP, Mercedes-A2DP and VW-A2DP - PRODUCT - ViseeO Worldwide Official Site
Works perfectly and also allows the phone to work too !!
I'm pleased with it and it didn't cost a lot !!
The following 3 users liked this post by bellingerp:
bigdhenderson (05-09-2014)
If it doesnt work with the Jag I will use it for my shop radio
...and I just tried the Tune2air with my iPhone 5 and 2012 XKR-S. Pandora will only play for one second and then stops.
What the f*#*!!!
Pairing is successful, the Bluetooth is working, but the iPhone just won't stream. Same thing happens when I use the cord with a Lightning adapter.
Help!
Rich
What the f*#*!!!
Help!
Rich
When you say "use the cord", is that when you connect it to the Jag iPod port via the Lightning adaptor? If that's the case, the Tune2air is not likely to be the problem; it would suggest there's an iPhone 5 compatibility issue. Or your audio system needs a reset - yoink, wait 30s then replace: fuses 21 (blue) & 24 (red) in the rear-seat fuse box.
Streaming is the problem.
Rich
What the f*#*!!!
Help!
Rich
What the f*#*!!!
Help!
Rich
Yah, BigD... nothing else is happening on the iPhone, just Pandora. Mixing up the activation order (starting Pandora before even opening the car door) doesn't make a difference, either. Shut down iPhone, restarted, no change. Pairing is perfect between the car and the Tune2Air, there are no problems docking the device via Bluetooth... but there's something else going on.
This is from the helpful folks at Pandora, who surprisingly replied to my email within a day:
It's a shame. The tiny fragment of music that plays sounds great.
Rich
Josh | Pandora
MAY 13, 2014 | 04:55PM PDT
Hi Rich,
Thanks for writing. A lot of "iPod/iPhone-compatible" docks and accessories have built-in software that trigger the onboard "iPod" MP3 music player on the iPhone, interrupting Pandora (or other audio software), since third-party audio apps like ours weren't a big deal when the accessory was designed.
You might be able to get it working by following a particular set of steps (e.g., connect the phone, then launch Pandora) but often it will only work correctly some of the time. Ultimately the manufacturer of the dock is the best place to go to find out how to get third-party apps working.
Hope this helps. Thanks for listening!
Best,
Josh | Pandora
Listener Advocate
PANDORA® internet radio
Need help? http://help.pandora.com
Hi Rich,
Best,
Josh | Pandora
Listener Advocate
Rich
