HELP! Top Down, Car won't start, top won't raise
Ha, I did the same thing when I bought mine. I tried to re-charge the battery and it started strong for a few days, then a sudden no start situation again.
You don't really know the state of the battery and this car is very temperamental under less than ideal battery conditions.
Just get a brandy new battery. It's worth the peace of mind.
My car will not start and I had to find a way to get it into neutral so that it could be towed. There is a video of how to do this on Youtube. There is a mechanical lever under the rear shifter that you have to use a long flathead screwdriver to push it and at the same time pull the gear shifter down into neutral. I hope that this helps.
Here is that link:
Here is that link:
Yes, there is a screw under the console hole that can be removed and a rod shifted to release the park to enable towing on the XK.
Received 2,059 Likes
buzzojoe
12-14-2017 08:35 AM
insomniac_driver
21
08-20-2017 05:17 PM
