HELP! Water under carpet (not drain tube, I guess)
Couple of month ago I realize that my passenger carpet is soaking wet. After googling I decide that is possible cause is duckbill, but water was only in rear end of carpet. So, when I was looking for a hole i find one of bottom drain plug and it’s sealant is damaged. I seal it all over, but after rainy drive I find my carpet wet again. So, I have sealed other plugs especially vertical in the area of the fuel tank, but water started to leak in gearbox area. I have seal any other holes and joints of passenger side and... I realize my drivers carpet soaking wet too. I’m tired. Have you any suggestions?
BlueJeans1979 (05-22-2024)
Sounds like bad sealing between bodypanels underneat your car. You don’t state wich year your car is. Could be interessting to know as others also has the problem but not aware of it, and it could be related to a productionseries. Good luck solving the problem and let us know the result
If you have water on both side of the tunnel, your absolute best bet is to pull all the carpeting out, vacuum the floor and underneath the carpeting, hang the carpet out in the sun to dry it 100%. Drive the car a few days without the carpet installed, set A/C on Max to see if it’s the drain, water entry only when it rains or if it’s coming from somewhere else. If you go as far as spraying the car down with a hose and spray nozzle, do not spray on it from a horizontal angle, you want to replicate a normal rain shower, not chase water leaks from an uncommon direction such as horizontally. Ask me how I know.
Addicted2boost (09-10-2021)
Addicted2boost (09-11-2021)
Now you gotta do the other side the same way. My philosophy is one and done. A lot of work is taking the proper steps to methodically and throughly complete the job so you don’t have to go back and do it all over again. Taking the carpet out like you did and throughly drying it out so there’s no musty odors and/or mold growing under the permanently damp carpet is 1) a sure fire way to substantially reduce any respiratory system issues and 2) enjoying the car in the long run.
So, think I should write about my case and determine what was happen. Surprisingly I got five spots of water leaking. Some was by my fault, because on our roads, especially near malls entry, is hard speed bumps and XKR clearance is not enough to overcome them without hit the bottom. So, once or twice I hit the bump and, guess, this is was main cause of.
Floor sealant behind the both of seats was cracked. But these drain plugs was leaking too on passenger and driver’s side and how to explain this IDK.
Another spot of leaking — cracked sealant of joint of floor panel and rocker panel (beyond driver’s footrest)
