Help with wheel spacers on 07 XK Coupe
Hello everyone,
I'm looking for some help/suggestions from those that have installed H&R DRM 20mm spacers on their XK's.
I've just started to install my spacers on the front wheels, but when I go to mount the tire back on, it seems that the factory bolts are too long. My Senta's have holes in the back which technically would accept a stud fitting into the cavity, but the bolts are about 1/4" too long preventing my wheels from sitting flush. Is my only resort griding downthe unthreaded part of the studs, or am I missing a step? (See attached picture).
Any help you can provide would be appreciated.
Thanks!
MPRESION
Thanks!
MPRESION
I did not have any problem with my '08 XK rear wheels and the 20mm spacer. I did, however, when I put 15mm on the fronts. I simply used a high speed cutting tool to cut off the leading, non-threaded portion of the wheel bolts.
I just installed the same set (after selling my '08) on my new XF and it worked without any mods. The standard XF wheels have more indents than the XK had. If you do not like cutting, you could always purchase a set of new, shorter wheel studs from any automotive store.
Albert
Albert
Hello everyone, so after a bit of labour, I finally got the spacers on.... what a difference in stance! The car has 20mm spacers in the front, with 5mm spacers in the rear, plus the lowering springs from Spires. I literally finished the install about 30 minutes ago, so hopefully I'll be able to get some pics posted tomorrow in the daylight.
![Icon Steer](https://www.jaguarforums.com/forum/images/smilies/icon_steer.gif)
Glad you like the difference. It is substantial to the point that even my wife noticed how much more aggressive the stance was with the spacers. The 20mm front and 15mm rear is the correct setup; I was mistaken when I listed mine backwards. I did it a good while back and I no longer own the car. But, used the very same spacers in the reverse setup (15mm front, 20mm back) on my new XF. Made a similarly significant difference visually as well as handling wise.
Albert
Great!
Albert
Albert
As for the rear spacer size, 15mm would have been too much on my XK in the rear which would have pushed it out too far. The 5mm worked perfectly on mine to give me the desired stance.
Funny enough you say the comment of your wife noticing...cause after I completed one side, my wife came out into the garage, looked at the side that was done then walked over to the other side to compare, then she says "wow, that makes the car look so much better"
I guess someone gave you a good deal on those wheels...
20mm - 4035633
15mm - 3035634
White Bear (05-08-2013)
Do you know how much in inches/mm's the springs lowered the car?
What's the part number of the Spires springs you used?
I'm assuming this did not affect your camber/alignment...
TIA
I chose Spires for a few reasons, first because I did not want an overly agressive drop. I considered H&R and Mina, but chose Spries because of the minimal 0.8" drop (20mm). Also, the Spires springs are manufactured by Eibach exclusively for Spires, which gave me reassurance of a trusted brand.
I ordered these directly from Spires UK as their distributors are not authorized to ship overseas.
As for camber, no effect at all. I did do a realignment immediately afterwards.
As for the bolts, it was a minimal grind, only a couple of millimeters, and everything worked out well. It did not affect the threads as just the tip of the guide was shaved.
I hope to have better pics up soon... Just really haven't had much opportunity to get to it.
MPRESION
MPRESION
rscultho (05-23-2013)
Ride is a tad bit firmer, but did retain a lot of its comfort. It was the perfect compromise for me.
I sent an email to Spires asking if they had a distributor in the US for the springs, and included my car stats.
Interesting response...they said the lowering springs could not be used on the MY 2010+ XKR.
They are fine for the non SC (XK), but not for the XKR.
So, I am back to square one. For me, 1.3 inches or more is too much of a drop. The 20MM/.78 inch drop would be perfect.
