Help . Wife is boiling hot.
Took her out shopping and her side of the air vents was pumping out warm air ,and it was 98 outside ,my side was cold but could not keep up, not ice cold but colder than her side . anyone had this problem or have sujestions . never a problem before but then it was never this hot. Thanks.
The following 4 users liked this post by Cee Jay:
The following 2 users liked this post by BruceTheQuail:
FrickenJag (07-07-2015),
sherbercars (07-23-2015)
Mine always blows hot air for a minute or two after startup (car, not wife). Our temps are pretty high in summer, around what you are saying.
After a couple of minutes the air cools down. I haven't had that issue with any other Jag, it seems to be peculiar to the XK.
This problem was all the time .
I wish could get mine to blow all the time , ( not the car )
BruceTheQuail (07-06-2015)
Received 2,011 Likes
sherbercars (07-06-2015)
Received 9,010 Likes
By the way how is the rear/ front camara coming along ??
See below, not sure if it relates, but could help?
https://www.jaguarforums.com/forum/s...heating+issues
https://www.jaguarforums.com/forum/x...highlight=dccv
Jim
Jim
I've complained to the service center at the dealership to where I bring my car about the really slow start-up (at least 3-5min) for cold air when set to AC. They claim they have tested the system and "all is good".
It's sad that my 4Runner blows cold air faster (almost immediately) than my Jag...
sherbercars (07-18-2015)
Same here where pass side warmer than driver and usually an indication the freon is low. definitely check that first.
Charged mine and all was good. In fact it was so good that I ended up with the dreaded water in passenger well due to the poorly designed duck bill drain in the 07XK.
Guess the previous owner removed freon to either mask issue or that was their solution.
3jagfamily
10-01-2015 01:49 AM
dmatthewman
09-30-2015 10:10 AM
