HELP!! XK won't start after cleaning seats...and the fob is stuck!!RESOLVED
Update #2: went to check the charge at around 9am, so that's roughly 11 hrs of charging. I opened the trunk to check the ctek: only 4 LEDs out of 7 so far and the quick beep was still there. Fortunately it's not too loud and stops fairly quickly... I just hope it's just due to the low charge and not the sign of something truly messed up.
Haven't tried to start the engine, though. I'd rather wait for the rest of the day. I don't have to drive before tonight anyway. Glad this is Sunday!
The following 2 users liked this post by George05:
Cee Jay (05-30-2021),
George Abitbol (05-30-2021)
George Abitbol (05-31-2021)
Good George . Short runs will deplete the battery , buy the new charger put it on overnite battery will be Fully charged , ctek had a faulty batch a while back model ms5 I believe my mate Steve had loads of problems with his and had to replace a 3year old battery due to ctek failing to do its job . Just stick 8-10 amp charger on overnite say once a week battery will be good . Ps hope your car starts ok today
#28
The following 2 users liked this post by jagtoes:
Received 1,123 Likes
yes. A battery can be had for the cost of 2 tanks of fuel. Or 1 nice dinner out. Get on with it and stop mucking about trying to revive a done battery. Time is money. How much time has been wasted thus far?
And as George and Cee Jay have suggested; get the new battery on a charger to ensure she’s fully charged bofore going through this situation again.
#30
#31
Update #3: checked the charge earlier this afternoon and the ctek was indicating a full charge, all 7 LEDs lit, including the green 7th one. Looked good. No more beeping in the end. So I decided to give it a shot. The engine started without a problem. What-a-relief!! ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Now, like you guys suggested, I need to make sure about the battery, whether it needs to be changed or not. I've left the doors open for a few hours, moved the seats back and forth and had to turn the ignition on a few times as well (otherwise the seats wouldn't move). I don't know if that's enough to drain a normal XK battery or if it's the sign mine is nearing the end of its life...
Now I'm off to giving it a good cleaning outside, after taking care of the interior yesterday. Now I know I have to hook up a charger to the battery before doing so, just to be safe...![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Anyway, many thanks to all of you again!
tberg (06-01-2021)
#32
Hey George. There are two simple ways to test your battery. If you have a voltmeter, let the car sit overnight and off the ctek, then check the voltage in the morning at the battery posts. If it reads less than 12.6 volts, it needs to be replaced. The second and easier way (imo) is to drive to an auto parts store. They will load test it at no cost to you. Good luck and glad you got her up and running again.
The following 2 users liked this post by Sean W:
#33
After I arrived to the office I checked it again and then it read 11.7V, but I guess it could be linked to the fan that cools the engine off after turning it off...
#34
#35
I looked it up this morning...thanks to the FM transmitter via the 12V socket. I don't know how accurate it is, but it read 12.1V before starting the engine, which started fine.
#36
That being said, let me remind that it's the indication coming from my little FM transmitter, plugged into the 12V socket, therefore not measured on the battery's poles. This might make a difference, I don't know...I need to get a voltmeter, I guess.
#37
you have a few options for multimeters. for about $80 you can have a decent one, usually 10A, 12A or 15A rated. this doesn't enable you to diagnose absolutely everything in a car, as there are sure to be some 50A circuits, but you can at least test voltages to your hearts content: these are almost all capable of 600V or higher, which covers damn near everything in and around a home. i'm not a tech nor even a thoroughly experienced DIYer, but i've done enough, and never needed nor see any occasion in the future to actually have to measure current on a circuit over 10A. buy replacement fuses in advance of needing them.
you can also get super cheap meters. they're accurate to a tenth of a volt (kinda), and if you only ever want to use it for this one specific purpose, it'll do fine. but at that point why not just get a fancy battery charger/maintainer/tester if the objective is to service only the battery?
#38
How about a bad alternator? You could have just been draining a good battery for the entire trip because it wasn't getting charged.
You really need to go to a place that can do a quick check of both the battery condition AND the charging system. Any auto parts store in the US does this for free, may be the same in the Land of Lux.
guy (05-31-2021)
#39
DpezXK8
04-23-2015 02:43 PM
Dv201269
04-11-2015 07:34 PM
dannyS
07-22-2013 11:12 PM
scottishjohn
04-06-2013 02:24 AM
