Hood/Bonnet lining
Received 9,010 Likes
I've seen some videos shot from inside the car of similar cars to mine and you can hear the supercharger - I can't really on mine, only very faintly when at very high RPM. I sort of wondered if that was because the bonnet lining was removed.
I've removed the bonnet lining on other cars in the past to hear a little more engine/turbo noise but if it's needed to prevent heat damage to the paintwork then I'd leave it be. That was all really
If you remove the hoodliner you will definitely hear the engine and supercharger more. With the vents it is going to be next to impossible to damage the paint from heat. If anything the hoodliner holds more heat in and if you're really worried about that then get some aluminium duct tape and line it to reflect the heat. It will be more effective for heat than the hood liner - lighter - and let you hear the noises you're looking for.
