Hood open warning with hood closed
I used contact cleaner on the sensor. It was noted that you should ensure the cleaner is dried before reconnecting the wires on the sensor.
https://www.jaguarforums.com/forum/x...3/#post2275766
I had the dreaded warning today when out for a drive in our 12xk vert. I found that the micro type switch's U shaped wire was bent down and not making contact with the bonnet's latch bracket. (on driver's side)
I used a small thin screw driver to gently flex the switch's wire up so that it would be contacted again. Seemed to work like a charm for me.
V7Sport (06-13-2022)
I had the same message last year. After checking and testing the 'front hood' latch switch, I realized it had something to do with the convert. roof. Ended up just being the divider tray in the trunk for the convertible top wasn't making good contact in it's tracks.
Cee Jay (06-13-2022)
