Hood Struts
Check out: 2000-2014 Jaguar XKR Hood Strut - Rhino Pac 6585 - - PartsGeek.com. They're about $30 and easy to install.
DaveC (11-24-2015)
If you have a friend help you, it makes it easier and safer. If both struts need to be replaced because the 2 together won't hold the hood up, have someone hold the hood up while take off the first strut and install its replacement. Ditto on the second strut. And, when you close the hood, always hold it in the middle or you'll often get only one side to latch but not the other side.
