Mine horn doesn't beep when I lock. Is it supposed to? I searched the forum and the only thing I found was an old thread from 2010 which basically said that's the way it works. Is that correct? It's rather irritating to have to look back at my car to see if the mirrors are folded to know if it's locked.
On North American market X150 models, the beep means "Stop pushing the lock button, I'm already locked."
Continuously locking and waiting to hear the error message beep will cause your sounder (the beep module) to fail and never beep again. Ask me how I know.
The choice is yours. You can either look at your side view mirrors and confirm that your car is locked or eventually replace the sounder.
The way I see it, that beep on the second press isn't an "Error" message, but a sounding to let the presser know that indeed the car is locked. Fords also do this, and it isn't an error or a malfunction. Since the first press is silent, who knows if the car actually locked when not within the slight "thunk" noise, or not facing the car to see the lights flash? Many cars have a beep on the first press, thereby letting the presser know the car is locked. Jags (and Fords) are kind to sleeping neighbors and have a bit more decorum as to not have an irritating "BIPPPP" upon ever Lock press. It's a feature, not a malfunction (or error).
I had a malfunction of the solenoid that powers the locking mechanism and when I would hit the lock button the car would beep two times. The mirrors would not retract BUT the alarm would come on. Since I got that straightened out the only time it beeps is when it is "double locked" per the owner's manual.
North American market X150 models are not equipped with the European double-click feature, which prevents the doors from being opened from the inside. Europeans consider the to be a theft preventer but we Yanks considered to be a safety hazard that prevents a child locked inside a hot car from opening the door and escaping. The double beep on North American market models is an error message that the doors are already locked.
Page 30 of my owner's manual describes two different alarm settings depending on the number of button presses. According to the manual, one press sets a "perimeter alarm" which sounds if: •The bonnet, luggage compartment or either door is opened •The vehicle battery is disconnected •An attempt is made to disconnect the alarm system •An attempt is made to start the vehicle without the smart key present.
Two presses of the lock key sets the "full" alarm which along with the perimeter alarm functions adds: •Movement is detected within the vehicle's interior. •A window or front or rear screen is broken •The vehicle is raised or tilted.
I see nowhere that describes a situation where the car cannot be opened from the inside. According to my manual there are two levels of alarm, hence the "double lock".
In the service manual I found something called a "battery backed sounder". I'm slightly disturbed that they left out the hyphen, but I'll get over it. In any case, THAT is apparently the sounder for the security system. It doesn't use the horn, like most cars do these days, it uses a separate sounder like a cheap, aftermarket security system.
I guess I need to go find that sounder and see if it's still working. I've never heard it chirp.
The manual says it in the right rear of the engine bay on the firewall.
There’s a thread around here where someone replaced theirs. Think it was under the coolant reservoir.
My car is apparently fitted with #8, the "passive anti-theft horn", not #9, the "battery-backed sounder". It's super-easy to access. I just took off that little plastic cover on the right side of the car, directly in front of the windshield, and there's a cavernous area behind the wheel arch with a couple of connectors and the passive anti-theft horn. I jiggled the connectors and tapped on the horn, and when I double-clicked the lock button on my fob the horn emitted a weak, pitiful chirp for about a tenth of a second. I jiggled and tapped some more, but I couldn't make it chirp again. Clearly the passive anti-theft horn is bad.
Does anyone know the part number? The manual doesn't list part numbers.
Mine looks exactly like this picture, except instead of having two spade connectors as shown in the manual, mine has a single plug with a plastic connector.
And it's located here. There's enough room in there to fit both arms, some tools, and a small puppy.
That is because handbooks are region specific. Yours probably starts JJM 18..., one for the UK is JJM 10... and they have this section in them:
And this:
That all makes total sense. But it still doesn't mean that the second press on my door locks is "just a warning beep". My manual refers to it as a double lock and the alarm system is engaged at a different, stronger level.
OK, correct, incorrect whatever, could you go to the area where it talks about the car alarm and tell me what it says there?
Or just forget it, I'll get a friend and test it myself.
Originally Posted by u102768
... this is the correct section for your car from the US version:
De5in,
You're in the USA. If you don't understand what the above photo of the relevant section of the manual says, then scroll up to my Post #6 in this thread and read what I wrote on June 22.
For US market X150 models, the double beep is an error message indicating that the car is already locked.
