How to change a speed limiter value with SDD?
Hi,
tried to change speed limiter setting for my MY2010 XKR. Logged to SDD with a golden key and adjusted CCF. Found a line with speed limiter - changed from 250 to 300 but actually settings are still the same. Car "stops" over 250 (+5-10).
Did anyone succeed with SDD? What are necessary changes in CCF to make it work properly?
MarkyUK (11-01-2020)
It is downloaded (weird again - I would say uploaded ) and perceived as a setting in main and two backup computers.
I changed, saved, car was turning on and off couple of times and finally it undergo an error codes erasing procedure.
So I bet it was done properly. I changed also audio settings and they affected a car (they made a radio was not working - so I changed it back).
Jaguarsmg1
09-26-2023 05:38 PM
MoscowLeaper
57
08-25-2022 12:50 AM
