How did spacers affect the handling of your XK(R)
Old 08-25-2020, 02:38 AM
neilr's Avatar
Originally Posted by peterv8
For track use I agree but for road use it's alot of bla bla bla. I have not notices any difference in steering with my spacers and I have even lowered my car which should make it undrivable ...
In reality it is completely the opposite. Car manufacturers go to massive lengths testing their cars to make sure that they have the best compromise of characteristics, especially to make it consistent and safe for drivers with ordinary skills under a massive variety of conditions. On a race track, the aim is the best lap time. The driver has to cope with the other compromises and has much more skill to do so. A race track is also a much more controlled environment. You know every dip and odd camber, you know the surface coming into a corner, and you can adjust a whole host of settings on the car for each track.
For the layman to make fundamental changes to a car could be viewed as irresponsible. Most of the time we get away with it as we drive way below the capabilities of the car. However, under the wrong conditions, you may find yourself in a ditch when if you were in an unaltered car you would have coped. So you make changes at your own risk and knowing the risk is a good starting point. With all due respect, not being able to feel that the car handles differently with such a major change as far as a road car is concerned is no proof that it does not handle differently.
I'm also not convinced that sticking out wheels looks better than where they were originally put on these cars with already huge wheels and tyres. When I look at mine, any bigger and wider would simply clash with the flow of the car. Might work on a boxy BMW but on cars that are elegant and well proportioned to start with, it just looks like one is trying too hard to make it look like a track car.
The following 2 users liked this post by neilr:
barnsie (08-25-2020), ralphwg (08-27-2020)
Old 08-25-2020, 03:10 AM
peterv8's Avatar
Each to their own!
XKDreams (05-22-2024)
Old 08-25-2020, 05:50 AM
kj07xk's Avatar
Received 2,048 Likes on 1,372 Posts
Even if the components can handle it, the car manufacturer needs to be conservative in wheel placement to avoid tire rubbing at the suspension upper limit of travel.
If you push the wheels outward, and have a beefy tire, you could have some (or a lot of) fender/liner rubbing if you ‘bottom out’ on a large bump.
They don’t want to get complaints about it.
You, on the other hand may decide to take that risk. Your car, your choice.
kazi
05-09-2019 07:39 PM
indietor
01-05-2018 11:57 PM
Salo
07-26-2017 04:38 AM
Fstbmw1
04-14-2015 06:51 PM
R.N. from Hell
09-07-2013 04:21 PM
Quick Reply: How did spacers affect the handling of your XK(R)
