3 min to pull power antenna fuse, look in owners manual , locate 15 amp antenna fuse, (called Ariel) remove center rear upper seat cushion , seat cushion simply pull out one inch, then pull straight up to remove..entire job 3 minutes !
If I am correct, it is actually a 10amp fuse in position f4, behind the rear centre seat.
Hello to all,
I'm sorry to relaunch this post with a very simple question: do you know where is the antenna of my 2007 XKR? Indeed I don't have a retractable antenna, besides the radio works so badly that we can wonder if they didn't forget the antenna!
