How do you read eng temp on a 07 XK
Before I bought the car, they told me that the temperature ran hot so it had to be repaired. The thermostat was replace and it seems to be fine BUT I have no idea how to "keep an eye" on the coolant temp. There are no gauges to check if the engine is running hot or normal. Please advise.
Sean W (11-08-2016)
It works perfectly, and has literally hundreds of parameters within.
Would you have the link for that Cee Jay, ralphwg i have a Maxiscan ms300 OBD 11 CODE Reader, got it a few years ago, it works and tells all codes on the bluetooth app, whats the story there, i havn't got that
Super Mini OBD2 OBDII ELM327 v2.1 Android Bluetooth Adapter Auto Scanner Torque | eBay
Received 2,012 Likes
Thanks!!
Appreciate your feedback.
Why is that KJ? There is a BT/ WiFi for android too. Is there a problem with iPhone and BT with this or some other reason? I ask because I use Republic wireless and have to connect to wifi to use it, which basically means if I'm out in the middle of nowhere (often) I have no wifi connection.
The wifi OBD reader generates its own wifi signal, i.e. it is a wifi 'hotspot'.
So after you plug the reader into the OBD port (and turn it on, if thats necessary for that model), it will generate a wifi signal. You then go into your iPhone's wifi setting and find that 'network' being generated by your OBD device, and 'connect' to it.
You then go to the app on your phone that interprets the data, and start it up, and perhaps do a 'connect' to your vehicle.
(This is exactly what I do with my iPhone and the wifi OBD reader that I have. Although I don't need to use it to read engine temp, as I have that displayed on my infotainment screen via my HKS Camp2 and GVIF setup. But I do use it to read/reset engine codes.)
Does that help?
Probably true, but some of us are stuck in 'apple hell' because the significant other wants an iPhone, so she can be the same as her friends (and I have no desire to support 2 different phone platforms, hers and mine), so I cave and she gets the iPhone (but I got the Jag!
![Icon Dance Tap](https://www.jaguarforums.com/forum/images/smilies/icon_dance-tap.gif)
