How do you reset the Navigation?
I got into my 07 XK the other day and the current location of the car in the Navigation systems is way off. Not just a little, but miles off. So if I try to use the Navigation, the turn by turn is way off. Is there are way to reset the system so it starts with the correct location of the car?
Thanks,
Ken
Thanks,
Ken
Here's the relevant section from the Navigation handbook:
Ken's question surprised me as I've never needed to do this even when travelling through Eurotunnel from England to France (30 miles) or Mont Blanc Tunnel (7 miles) from Switzerland to Italy. The navigation has calibrated itself to the new location in a few minutes each time although changing discs is required as UK, France and Italy are spread across three of the four discs in the European set..
Thanks,
Ken
Thanks,
Ken
Richard
The following 2 users liked this post by RichardS:
bgpenguin21 (07-25-2023),
guy (02-24-2024)
Never noticed this. Learn something new every day on the forums.
Thanks,
Ken
I suspect that water has corroded your GPS antenna under the rear spoiler and it will no longer be able to determine its correct location. Exactly the same happened to our 2006 XK. I replaced the antenna with a much better modern one which is mounted within the boot and can never suffer the same fate as the original. The total cost of replacement was $25 and it takes about 5 minutes to unplug the old antenna and plug in the new one. I posted the details a year or so ago.
Richard
Richard
Ken
Interesting, I will look into the antenna replacement, too.
Because every once in a while, my navigation system will get lost somehow somewhere - a phenomenon I never had before with any of my cars, including the two prior XKRs.
Locking down the car for a little while will initiate a re-start of the system with the correct location; otherwise I have to “recalibrate”…
Note, however, this is the one and only complaint I might have about my “old” XKR 4.2.
Received 2,048 Likes
The cable you need to connect to the DVD player in the boot is https://www.ebay.co.uk/itm/254151428682
Hope this helps.
Richard
kj07xk (07-26-2023)
It has taken me a while, but I finally resolved the problem. I replaced the GPS antenna (Part # C2P24351) and the Navigation immediately started working as it should. Attached is a pic of the old antenna. I would add "Resolved" to the title of this thread, but I don't know how to do that.
Thanks for everyone's help!!!
Ken
Ken
The following 6 users liked this post by khsjsilver:
Cee Jay (02-29-2024),
guy (02-24-2024),
Hans Amstein (02-24-2024),
kj07xk (02-23-2024),
ralphwg (02-23-2024),
and 1 others liked this post.
