How full do you fill your fuel tank
On some of my other vehicles I have a tendency to fill the fuel tank with as much fuel as possible. I mean that there is fuel all the way up the filler neck. I also know some cars have a fuel vapor recovery system which has a vent hose near the top of the filler neck. Do I assume Jaguar has the same set up and if so how far down is the vent. This would give me an indication where I need to stop the fill. With a lot of the oxygenated gas the foam usually triggers the hose off so I need to wait and fill until I get my desired level. What are others doing.
I stop adding fuel/gasoline once the pump shuts off automatically.
Otherwise it is likely that the gas can overfill trying to get 1/10th of gallon extra. Then you have gas running down the side of the car on the paint.
There are many articles written why you should NOT overfill the gas tank.
HowStuffWorks "Avoid Topping Your Gas Off"
Nothing to do with OCD just getting more miles. While pumping you don't see the foaming of the gas . This triggers the nozzle to shut off. If you were to look into the fill neck the fuel recedes below it. The trick is to find the sweet spot and do a slow fill to that level. In my Lexus that is about 2 1/2 gallons which is safe and below the vapor recovery vent. Range on the Lexus V6 is about 480 miles at highway speeds. It will be interesting to see how far the Jag will go. I'll be taking a road trip next month and we'll find out.
It just surprises me how apparently there are people who top off their gas, despite all the warnings on the fuel pumps and in (probably) vehicle owners manuals forbidding this practice. I already had an XJ6 with a clogged vapor recovery system that ended up creating a negative pressure in the fuel tank(s). Allowed to continue, the fuel tanks could've imploded!
https://www.jaguarforums.com/forum/x...mplode-112224/
Correct me if I'm wrong, but foam is comprised of liquid. Ever wash your car and get foam bubbles on the ground. Once they pop, isn't the ground wet?
Plus a lot of times, fuel in the ground is colder than ambient air. If you fill up and park your car for a few hours, fuel can expand and then you will most certainly have a problem.
I just finished parking the car on the lift today and had another chance to look under it. I see Jag continues with their twin gas tanks but I couldn't see the crossover pipe. I followed the inlet pipe up to the gas cap. Up near the top of the filler neck just behind the gas cap there is a small can located down about 6"-8" below the fill cap. This looks like a small liquid/vapor separator. So the net for me is I can fill the tank about 8" below the cap. Next to the vapor can just above it is the tubing that goes into it and then there is a piece of overflow tubing that runs along the lower fender panel. Just a little info in case anyone wanted to know.
No trouble - I did a 260 mile trip recently (east London to Fishguard, Wales), cruising 80-85 most of the way, and still had 30 miles showing on my range when I arrived. And I wasn't being deliberately gentle, because I'd assumed I'd have to stop for gas - the range showing when I started was 230, but I guess that was based on my normal city driving. I've since noticed that, after a long motorway drive, a fill-up reports 305 miles range.
jagtoes (07-21-2014)
Received 1,103 Likes
I guess my bladder usually goes before the fuel tank does!!!
As i looked at the tank and based on the earlier post I see it is a saddle tank I have a new question. The inlet from the fuel fill is about 3-4" up from the bottom of the right side tank. I also don't see a cross over pipe and the fuel pump is in the left side saddle tank. I wonder what the inside looks like because I can't see how the fuel gets from one side of the tanks to the other. Just curious not ****.
All the plumbing is internal. These pictures should help.
To answer the original question, I always fill my tank until the pump cuts off then carry on to the next complete litre. Not sure why really, maybe it is my OCD, but I have never had an issue doing that (other than wet shoes once!).
