How to improve the exhaust note
Hello,
I have a 2007 XKR. I would like to improve the exhaust note without changing out the stock exhaust system. Has anyone removed the secondary resonator/muffler ? If so what were the results. Will it still pass California emissions ?
Thank you for your time.
Gregg
Gregg
mosesbotbol (10-09-2019)
Corvette guys have for years used a thing like this controlled by the garage door HomeLink pad; link it to the Fuse Disconnect and with a press of a 'garage door' button, the valves open and close.
Would be easy to replicate something like this if you wanted to... 1 switch mounted somewhere for convenience, 2 pieces of wire from switch to rear fuse box and 2 blade connectors to go in place of fuse 19... Probably would make sense to also add a mini fuse holder at the rear on one side with the correct amp fuse to protect the wiring...
shemp (10-09-2019)
barnsie (10-09-2019)
http://www.cccharger.co.uk/
The following 2 users liked this post by mosesbotbol:
Queen and Country (10-09-2019),
TexasTraveler (10-09-2019)
