How to program Homelink garage door opened
Texasbill, thank you for the quick response. I tried 2 door opening motors, 1 with and 1 without a learning button. Again as I first said, the Jag XK homelink accepts the signal from the remotes, but the door doesn't operate. In other words the receiver in the motor is not getting the signal from the Jag homelink. I am really baffled and frustrated.
Welcome to the forum JPOrrico,
I've moved your question from XK8/XKR to XK/XKR forum. Members here with the same model who use this feature will be able to help.
What is the brand and model type of your garage door opener. I have a chamberlin unit that would not sync. up with my 2012 and had to buy a converter unit in order to make the opener work. My 2010 Lexus worked without it but my 2012 Jag didn't. Call your opener manufacture and see if they can help you out.
JPOrrico (05-29-2018)
'15 Jag XK
To TexasBill, I was mistaken on my first response. BOTH garage door openers have a "Learn" button even though they are different makes. One is a few years old and the other is brand new. I tried the instructions process on both but still cannot make the door open. This forum site moved my question to "XK" so I get views on the exact same model as mine.
The one annoying thing about HomeLink....... FIRST you must program the HomeLink inside the car to the correct frequency by using an already-operating hand-held remote. The instructions are in the User Manual. Step-by-Step.
What a lot of people DON'T know:
HomeLink systems are from the factory set up Per-Button; #1 Button for Genie; $2 for Chamberlain; #3 for something else, can't remember. When the HomeLink is cleared using the two outside buttons as-per instructions, this is the stock configuration.
Orthodixie (05-30-2018)
Cee Jay, I did program the HomeLink inside my '15 Jag XK from the already operating hand-held remote, exactly as both the garage door and car manuals state. Then the HomeLink inside the car indicates by a small red light going on that it has received and accepted the signal from the hand-held remote that operates the door motor. It is the final step that is not happening for me. That is the door motor is not receiving or registering the signal from the car's HomeLink. And using the motor's "Learn" button doesn't make it work either.
Frustration for sure.
PITA, but I always get them to work that way. I buy the cheapo 3-button universal remotes, then use all three buttons on separate occasions/vehicles to program the HomeLinks.
Then again, you may have a weirded door opener unit that just won't work.
Me, I'd go buy a new opener rather than a Bridge unit. Lots of things in my house are now WiFi connected, and while some are useless (My range? Why is a 'smart' range necessary?) others I use all the time (irrigation system, thermostat, security system, light switches etc). I don't have a connected garage door opener (yet), but I do look at the add-on wall controllers once in awhile.
I used to think all this 'connected house' stuff was Hooey, but it's actually kind of useful.
Cee Jay (05-29-2018)
Read this entire thread: https://www.jaguarforums.com/forum/x...-opener-75297/
Many thanks to all of you who so kindly responded trying to help me. I gave up and called my garage door service people to install those radio frequency converters. I'll need 2; 1 for each of the Linear and Lift Master. Then I'll see if my '15 Jag XK Home Link connects with the motor receiver. In the meantime I am using the hand held remote.
Hey "AllblueACR" my '15 XK is also "all blue" but the dark sapphire metallic with full caramel interior, including the entire dash and carpets. Yours looks to be a very bright blue. Can you send me pictures to my e-mail - jporrico@outlook.com? BTW I am in Seattle, WA. Where is Airdrie? And I also see you are a "Senior Member." At 75 I am definitely a "senior" but very new to this Jag Forum.
