How to remove center console wood trim pieces?
I am stuck, I cannot seem to get the Ashtray Veneer to Slide off. The graphic shows holding the Black plastic underside steady with a Screwdriver while having it 1/4 way open and Sliding the top veneer off. How much force do you need to slide it off? Feels like I will break the whole assembly.
The following 2 users liked this post by jahummer:
MaximA (04-01-2014),
U2vertigo1 (04-01-2014)
1. open the Ashtray approximately as far as the blue arrow.
2. put your screwdriver on the corner of the black plastic subframe arrowed in red
3. holding the subframe back with the screwdriver, pull the lid forwards using the handle arrowed in green
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/78562-how-remove-center-console-wood-trim-pieces-veneer.jpg?amp;d=1396392947)
It should release without much force.
MaximA (04-02-2014)
U2vertigo1 (04-03-2014)
