How to Remove the Chrome Window Strip and Rubber Molding?
As jahummer says, it pulls off. I had to replace mine as it was corroded. Start at the handle-end of the door, with the window down, and use your thumbs to push up on the moulding. If it won't budge, carefully use a plastic trim-remover tool to get in between the trim and the door and lever it a little. Once you have it eased away from the door, it will gradually push off as you work down the length of it. The trim piece sits on a small 'ledge' on top of the door. Mine was held on with four metal retaining clips but these had started to corrode and since metal (steel) to aluminium is not a great idea, I removed these and threw them away. The trim fits tightly enough onto the door 'ledge' that they are not needed, and I wanted to avoid future corrosion issues. I did this about a year ago and the trim pieces on both sides are still perfectly installed.
I did have a thread on it, or part of someone else's thread, but Search isn't showing it.
Chris N (09-03-2020)
Received 1,975 Likes
jahummer (09-02-2020)
