How to replace the rear brake pads on your Jaguar XK 2007 and up (with photos)
I recently replaced the rear brake pads on a 2007 Jaguar XK and wanted to share the procedure with the forums.
Here is the link: jaghelp.com: 2007 Jaguar XK rear brake pads
Anybody has any questions or comment please comment criticism is welcomed
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
ejjbee (01-31-2016)
Just wondering why there would be a problem with break in , on a surface with no problems? Understand scratches, out of true etc. but dont really understand why the metal a mm or two below the existing metal will be superior or different in this regard.
I suspect there will be some differences here but I have never had a rotor turned. They usually last if driven for normal street use in my experience up to 100K miles. If by some problem they warp then I would just replace them. Based on reading studies cutting rotors ends up getting them to the lower acceptable thickness which causes early replacement. As long as the surface is flat and score free then all I do is scuff the wear surface with emery or scotch bright . I use the usual 5 mph-60mph, 60mph-5mph pad break in process.
Anybody has any questions or comment please comment criticism is welcomed![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
I used the factory scan tool because is available to me, just place the parking brake into service position, but someone at home would disconnect the battery... no biggie...
Is a standard pad replacement except the calipers are screw in.. and you have to reset the parking brake otherwise you'll create problems
It would be similar to an XKR unless u have performance brakes.
Thank you for the guide! I used it last night to replace the pads and rotors on all 4 corners of my XKR.
I did disconnect the battery while the car was in neutral but later realized that would have done the parking brake reset.
If you're doing the rears, you're not going to get by using a pair of pliers and pressure to retract the rear caliper piston. You'll need the tool so make sure you have it before you start. I wish I had bought but I needed it right away so I paid $50 for the smaller kit at Harbor Freight,
I did disconnect the battery while the car was in neutral but later realized that my code scanner would have done the parking brake reset.
If you're doing the rears, you're not going to get by using a pair of pliers and pressure to retract the rear caliper piston. You'll need the tool so make sure you have it before you start. I wish I had bought this one but I needed it right away so I paid $50 for the smaller kit at Harbor Freight,
Oh, and a thought on the battery disconnect. It seems the general agreement is that rotors should be replaced at least every other pad replacement. With that in mind, the brake line is usually disconnected per the jag manual. In order to keep the brake fluid from leaking out the brakes need to be applied with either the "special" tool or just wedge some apparatus up between the pedal and the electric seat and slide it forward the right amount. This, not surprisingly, activates the brake lights. If you don't like a dead battery from continuous brake light illumination then, heck, you already needed to disconnect the battery anyway, so, dive on in and get that thing disconnected. Now the P-brake reset is just a lucky happenstance.
And remember not to close the boot unless you have your valet key nearby. I caught myself reaching for it three times.
I replaced my rear discs/rotors and pads back in the summer.
The rotors had a slight lip on the outside so did indicated slight wear.
If you have a lip then the new pads might be slightly larger then the ones you are replacing
and there not sit flat on the rotor. Might need a few more miles to bed in.
I used Mintex pads and rotors bought as a package for around $100 US.
The Mintex rotors are silver coated so stop then rusting . They look good as well .
Re the battery I did not disconnect it. I released the EPB by pushing down on the lever before starting.
I used a caliper tool to retract the pistons .
Refitted in reverse order. No issues what so ever.
EPB reset is in the used manual and a very easy process.
Took about an hour for both sides.
Might need to keep a check on the fluid level as if the reservoir is full beforehand then by retracting the pistons the level may
increase and over flow.
I have had the rotors/discs skimmed on previous cars but the cost is not much less than a new set of discs( non Jag of course]
but to OEM standard
but to OEM standard
It seems some just choose different places to cause their potential leak-points. 😉 The Jag manual seems to have concern of damage to the line while while fussing with the disconnected caliper in your method. I experienced leak difficulty reconnecting the line to the caliper with the banjo bolt. It is what it is. 🙂
Woo5ie (01-11-2020)
BrentGardner
28
04-26-2024 03:08 AM
