Howling noise in rear end when coasting
This is the second Jaguar I've had where the rear end pinion bearing starts howling on the highway when you are coasting. Is it a common problem, my car is under an extended warranty, but need some proof that this is a known problem through Jaguar. Are there any service bulletins on this at all that someone could point me too. Need to try and get this covered under warranty as it is a pretty expensive fix. Thank you in advance for any help on this.
Thang Nguyen
10-12-2015 01:25 AM
James007
09-06-2015 06:47 PM
innzane
09-02-2015 10:08 AM
