Huh? Whoowhat?!? DOH!!
Took 2012 Jag into dealership to get rubber seals around doors replaced due to bad wear under warranty.... You know the black rubber surround the door and window....
Now my engine light is on and the door side mirror won't dock on locking.
WHAT!!!!!?!?!
Good Grief....
WHAT!!!!!?!?!
Good Grief....
What the F!#%
The rubber seals they replaced was the seals around the door... the rubber near the windows... Its not a functional thing its just rubber... That needed replaced because it cracked. now the following was wrong from the moment I picked the car up:
1- engine light on
2- outside temp sensor says its bloody -44 degrees outside
3- the AC just blows warm air
4- the driver side mirror does not fold in on locking....the passenger side closes maybe the 3rd-4th time.
This sounds to be more of an system wide problem...not a simple outside temp gauge!?!??!?
Loth
PS- Prior to taking over the rubber on each side had some tiny slits from wear...BUT
1- the engine light was NOT ON
2- the outside temp sensor recorded correct temp
3- the damn AC worked
4- the driver side mirror worked fine...
WHOOOWHAT!?!?!!!?!??!
1- engine light on
Loth
Loth
Loth
Could be because of low battery? They may have left the battery run down while keeping the door open when they replaced the door seal. May need to reboot the electronics with a battery disconnect and reset. I thought I'd throw this out first as a simple fix. I can't see all of this stuff just happening all at the same time. If you still have the car you may want to try this first after charging the battery before taking it back the dealer. Shame on the dealer for returning the car to you like this.
Lothar52 (06-07-2014)
I would NOT worry too much. Try getting the battery up to full charge. Your Battery Tender or CTEK should do the job, and I am sure that once the charger goes green, then you know the battery is fully charged.
There are several posts on how to complete the battery/electronics reset. It appears easy, even though I never had to reset anything.
Most important is, the Jaguar is under warranty. Jaguar has the obligation to fix it, no matter what. Is this a pain in the ***? Sure it is. The Jaguar is your baby and you don't want anything to happen to it, but hey, anything can go wrong.
Keep up your spirits and if the battery isn't the problem, then contact the dealer who did the repair on Monday. Remember, be nice, and they will assist you I am sure.
Hang in there. You can and will get thru this BS.
Link to reset procedure:
https://www.jaguarforums.com/forum/x...nstall-113965/
Don't forget to disconnect ground from battery for 10 minutes before reconnecting it to start reprogramming. Charge battery before reconnecting. You can charge battery with ground connected or disconnected. Good luck.
Don't forget to disconnect ground from battery for 10 minutes before reconnecting it to start reprogramming. Charge battery before reconnecting. Good luck.
I will demand on Monday he do this in front of me so that I learn the procedure first hand. This has to be it.... apparently there was no code either given on the check engine light!
as we stand:
1- check engine light no code
2- driver side mirror not docking, right does so 3rd or 4th attempt
3- outside temp sensor readings off
4- A/C not functioning properly - blows hot air
I just opened the trunk..waited a second and closed the trunk... the LEFT TURN SIGNAL clicked.... I opened the trunk and closed it again, the LEFT TURN SIGNAL went off AGAIN.
WOW!
That has to prove it... this is totally electrical and likely a battery check/replace with a reboot/reprogram is necessary.
WOW!
Ryan:
Consider putting your cars on a CTEK 3300 or another brand of battery smartcharger. You will not be disappointed, and this will end electrical frustrations in the event of weak batteries. I have used one on my 2009 XKR for the last year without any electrical problems of any kind. I also use one for my 2014 Porsche and 2013 Hyundai. I have 3 CTEK's.
There is allot of links provided here for installation and thoughts about various brands. Amazon.com is a great source for the purchase and installation takes 15 minutes at best.
Amazon.com:
Amazon.com:
Installation guideline.....(for your models you will use the ground screw bolt in the wheel well for the negative. My 2009 is a bit different where I can simply use both the Neg and Pos terminals). https://www.jaguarforums.com/forum/x...lation-107738/
This should make it easy for you IF you decide to possibly proceed this way.
Amazon.com:
Amazon.com:
Lothar52 (06-08-2014)
