Huh? Whoowhat?!? DOH!!
#41
Just got off the phone with the dealership - They were not aware of the left drivers side rear view mirror having no power. They did confirm that the temp sensor was not in that mirror and that it was in the front of the car unrelated to the door. They said once the temp sensor comes in and they replace it they will look at the door as likely a wire is malfunctioning. Sounds like a plan - if they replace the temp sensor and the engine light, air conditioning, and outside temp are not gone/working correctly/reading correctly then well I guess that its not a bad temp sensor. They will have to take the door back apart I would assume regarding the mirror. Just waiting on the temp sensor to arrive.
Lothar52 (06-09-2014)
#42
Damn, I should have checked:
The ambient air temperature sensor is a NTC thermistor that provides the ATC module with an input of external air temperature. The sensor is hard wired to the ECM and its signal is transmitted to the instrument cluster on the high speed CAN bus. The instrument cluster acts as a gateway and transmits the ambient air temperature signal to the ATC module on the medium speed CAN bus. The sensor is mounted on the vehicle center line behind the lower front grill, and can be accessed from underneath the vehicle.
#43
They got anything in there about how to change a front reflector by the book?? The dealer wants to take the bumper off... Ive been told by those who have tried you can removed the front liner, have a good light... do it with leaving the bumper ON.
Wonder what Jag's official procedure is for this... if I could have a page number then I could say look up page so and so... NOW DO IT!!
Loth
Loth
#44
#45
Actually, you may not have to undo the whole of the rear shield - the two halves share a single stud at the top, so you may be able to undo the two bolts on the rear shield and bend it down enough to get the front shield off the stud. It's plastic, so it should have enough flex.
#46
Sorry, my book only covers up to MY11 (VIN B44939), so it doesn't have anything about those reflectors. If I were you, I'd take the wheel off, remove the rear splash shield (2 nuts, one push-clip and 6 Torx bolts), remove the front splash shield (13 Torx bolts). Then have a look - if you can reach the bolts/nuts that hold the reflector on, you can do it yourself.
#47
#49
OK, came across something last night: there is a temp sensor in the wing mirror:
The sensor at the front of the car is for the climate control system, not the engine. So if your mirror wiring is disconnected, the engine will have no accurate ambient temperature info.
AMBIENT AIR TEMPERATURE SENSOR
The AAT (ambient air temperature) sensor is a NTC thermistor that allows the ECM to monitor the temperature of the air around the vehicle. The ECM uses the AAT input for a number of functions, including engine cooling fan control. The ECM also transmits the ambient temperature on the high speed CAN (controller area network) bus for use by other control modules.
The AAT sensor is installed in the LH exterior mirror, with the bulb of the sensor positioned over a hole in the bottom of the mirror casing.
The ECM supplies the sensor with a 5 V reference voltage and a ground, and translates the return signal voltage into a temperature.
If there is a fault with the AAT sensor, the ECM calculates the AAT from the temperature inputs of the MAFT sensors. If the AAT sensor and the temperature inputs of the MAFT sensors are all faulty, the ECM adopts a default ambient temperature of 20 °C (68 °F).
#50
#51
This seems to be fairly common these days, FWIW my Freelander also has the ambient temp sensor in the mirror.
I doubt that it's a risk to the engine though, there is also a sensor which measures the coolant temperature in the engine itself, that would be much more relevant in an overheating situation.
#52
Lothar52 (06-13-2014)
#53
#54
It also says when the AAT sensor in the LH mirror malfunctions, then the ECM uses the MAFT sensor in the air intake area to calculate temp... If both are not functioning then the ECM adopts 20C (68F). I think these fail-safes would prevent a total shutdown of the cooling fan!?
I do however wonder if the MIL light is on because of the LH mirror not having power vs the front temp sensor (that displays a temp to the touchscreen and says its -44F out) .... How could that temp sensor cause a MIL (the one in the front)??. The LH mirror sensor is in the "engine" section... therefore I think that is where the MIL is kicking on.
#55
#56
It is not. I called to tell them there is a temp sensor in the LH mirror... they called back to tell me sorry we missed your call we did get the part in but the part was not the right part ordered. So they said sometime next week. At any rate... I will not drive the car now till its fixed - I drove it a bit yesterday and it worked fine (apart from the left mirror not working, the MIL on, and it touch screen external temp reading saying its -44F to 0F).
After purchasing the workshop manual... I am convinced that these cars are very complex!!!!! Its not just a simple jaguar... HoLy CoW there are a ton of modules and sensors!!!
I was wondering if we all shouldnt start buying extra sensors and modules NOW while they are still making them..... that would be crazy.... then again... I am CrAzY for these cars!!!
#57
As Cambo said, and as you've spotted in the manual, the ECM has another way to estimate external temperature, and a default if it can't. This has nothing to do with coolant temperature, which is measured elsewhere.
Basically, the correct fuel/air mix is partially dependent on air density, and that's dependent on air temperature - if the engine is sucking in cold, dense air, you'll need more fuel to provide the right mixture than if it's breathing warmer air. So, if the temp sensor is dead, the only risk you're taking is of the car running a bit rich or a bit lean depending on what the real temp is vs. what the car thinks it is.
And all of this is separate from the climate system and the temperature displayed on the touch screen - that's another sensor at the front of the car.
Lothar52 (06-14-2014)
#58
look further
Both sensors are twist and click plastic mounts
These sensors and coolant temp have absolutely nothing to do with the aforementioned outside temp sensor
The assumption that the water temp oil temp and oil pressure, isnt accessible on a xkr is a myth. These parameters are readily available in real time while driving the car.
Moreover, the assumption that torque pro app isnt able to provide them is also wrong. Although this isnt my tool of choice
A tremendous amount of misinformation, bad advice and poor guidance regarding water coolant monitoring and oil pressure monitoring, leading to engine damage have been on this forum for 2 weeks now.
It will only lead to disaster if the wrong advice is used on a vehicle
#59
The truly informed xkr owner is aware that there are 2 water coolant sensors on the engine. 1 is above the bell housing on the rear of the engine on the right side. The other is on the front of the engine on the left side
Glad to see you back.
Helpful post for all. Can you provide some info on how to obtain such things as in your post above. Oil Pressure, water temps etc. I think your knowledge would be so helpful to all including myself, who does not posses the knowledge that you have. I am always open to learning new methods of discovery from others like yourself.
Thanks for posting. Hopefully you can respond publicly or privately.
#60
SoCalBabe:
I am sure you are well aware that I was banned from this forum for 10 days.
I was informed that I willed be permanently banned from this forum thru IP address if I offend or am politically incorrect again.
As you are aware, I took an individual to task that blamed the manufacturer, for his melted engine after he ignored an intermittent warning light for 1 hour.
I truly believe that trying to extort a new car from a manufacturer due to ones own ignorance or abuse is a matter of moral turpitude. I also called the individual to task on that as it was posted on this forum. For that I was severely punished.
No one on this forum read with much critical thought how that engine was destroyed, except me.
The car owner, who blamed everyone but himself, got the karma he so desired.
He threw the dealer under the bus by complaining to Jag N.A., about the inaction of the dealer to fix his car post haste and forthwith.
The only friend he had that could have fixed this car and cover up the abuse and negligence is now his worst enemy.
I am confident that a Jag N.A. regional rep will discover the abuse and cancel the CPO and not allow the dealer to fix the engine at Jag's expense.
If you recall the expense to fix that car was at most several hundred dollars, to replace the water pump. But now that the engine was nuked the cost is a minimum of $7500.00 if you include a total rebuild or a new engine with labor time.
This is conjecture on my part regarding cost due to I havent inspected the engine. But remember he ran an over heated engine for at least 40 miles, which aint good for the bearings, crank, pistons, blah blah blah. I wouldnt be surprised if the entire engine didnt seize up
the forum members that reported me and had me banned should be proud of themselves. Besides, I am just another woman who graduated summa *** laude from M.I.T. No, I am not an intake coordinator in H.R. as in my profile
There arent any threaded pressure ports that can be accessed in the block to get oil temp and pressure as evidenced by my inspection of my car's engine. Oil pressure is thru an electronic sensor that doesnt allow threading for an oil sensor. I however did find a way to get the most accurate oil pressure and temp, in real time, + or - 1 degree, with the help of a fine Merlot and modification of the electronics
Furthermore, the water temp sensors cant be accessed either for gauges, as they are plastic twist click. However, I used the laser temp pick-up that I alluded to when I heated up my blower pulley, and then found the hottest part of the engine that had water access. I then used a calibrated water temp sensor that runs to a digital gauge or a smart phone
As I stated before, I will be more than happy to send pics and manufacturer part numbers, and a walk through to accomplish this task. However, I dont want to see this info anywhere on this forum or read that any member received the pm from you with the info I sent.
When I get thrown off this forum, permanently, it will be the forum's loss, not mine
Karma is a *****, aint it guys!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
