On the hunt for a XKR ....opinions please!
Apologies if I misunderstood but I assumed that your latest results were near sea level after you posted this on your other thread and your latest time slip was from there.
Perhaps because the CTS-v has 551 lb-ft of torque whereas even a standard 4.2L XKR has 560 lb-ft? It is also heavier than the XKR.
The weight of the driver would have some influence as well. I don't know how large you are but I only weigh 66 kg/145 lbs so if I was racing against someone who was 110 kg/242 lbs, that would be another 100 lbs to take in to consideration.
If you ever get a chance you should weigh the car with you in it so you will then have an accurate figure to work with rather than guessing because things like different types of brakes can make a difference to the weight as can wheels, different exhaust configurations, etc.
I was told Bakersfield track is the fastest track in California and closer to sea level than others but turns out it's still 750 ft above , and with weather conditions that day, Density Altitude around 2000 it was only slightly better than other tracks. We don't have a see level track in California unfortunately.
I had 220 lb of weight when raced last time vs previous time had 50 lb less.
To figure hp there is no better tool than a Dyno, gives DA corrections automatically and if you know your starting stock level it's very easy to figure out power. My case: 359rwh with pulley only - 7rwh for pulley= 352 , percentage of base 416hp gives us 18% loss
Tuned figure 432rwh +18% gives us 509 with error +-7hp. Easy breezy 😉
Hang on, you have been down this road before.
May I offer you a pedestrian's observation to the glaring.
You are consumed with fear of too much power and expensive maintenance.
This fear or challenge of such exotic ownership is the thrill you seek.
It would not be exotic otherwise.
That said, as several others have mentioned on this thread and tried to the first time around.
There is a raw-brutal power to the 510hp XKR that one never tires of. (perhaps because its wideband and visceral and effortless)
I have gotten bored with all others that were better on paper. They seemed like one-trick ponies that gave a burst of power on the bottom or the top and there is only so many times you can get impressed by the same song.
Perhaps because there is such dichotomy and contrast in the XKR between being a refined Rolls Royce like ride and the ruffian, that one is constantly impressed.
I wish I could bring my car over. Your track looks so much better prepared than mine and we only have 6 meets a year so are at the mercy of the weather.
H20boy
16
08-10-2014 12:12 PM
H20boy
09-26-2012 04:18 PM
Leedsman
03-28-2010 04:12 PM
