HVAC Blower Motor Control Module C2Z6538
For the DIYer. Should you determine C2Z6538 requires replacing because the blower motor doesn't work. As you may know, Toyota owned Denso is a supplier of some Jaguar components/parts. Jaguar C2Z6538 (MSRP $233) = DENSO 077800-1020 = AIRTEX 4P1642 ($100 @ rockauto.com & $165 @ advance auto & auto zone). You have to use the AIRTEX number in the rockauto search to find the part. It arrived in an AIRTEX box but embossed DENSO 077800-1020 Made In Japan. (Arrived in 4 business days from Iowa,shipping $ varies, there's a $5 discount code on the web.) (Wells JA 1764 and/or Carquest 53-69864 MAY be the same part, emphasis may.) The Airtex part # was not found on Amazon or eBay. (There's a method of repairing your own for a few dollars via a link found somewhere on the JF thread "blower quit", but the removal process refers to a different model Jag and module #.) It's apparently a proprietary part for Jaguar & Land Rover.
***STOP*** The Airtex 4P1642 did not work as a replacement for Jaguar C2Z6538. After DIY trying 4 combinations of the original control module C2Z6538, Airtex 4P1642 (Denso 077800-1020) control module, the existing Bosch motor and a replacement Bosch motor with the same nomenclature - the blower didn't blow. Later, the original motor spun when I had it bench tested. Flummoxed by my efforts, I took the car to a Jag dealer where the C2Z6538 was replaced at a cost of just under $500 and the blower blows. Apparently rockauto is mistaken about the equality of the two parts. I should have postponed the original above post until a successful completion. It takes less than half an hour for an agile young(ish) man to remove and install the C2Z6538 (disconnect 1 electrical plug, unscrew 2 screws, remove from rectangular hole in HVAC wall under the glove box, screw-in replacement, re-plug). I should have bit the bullet and acquired a genuine Jag part for the DIY adventure. Anyway, you could save yourself $250 labor if you DIY.
Last edited by GreyXK; 08-01-2014 at 04:22 PM. Reason: Pulled the triger before it was out of the holster.
If you will do a little more cross referencing of the number, you can get it from Rock Auto for $55. I just did. I think the number shows up on a differnt model Jaguar and LR. But I looked further and it listed it as the same for the 07 XK. Good Luck and Good Hunting. If I remember tomorrow, I'll post the number.
GreyXK (07-15-2014)
(I dropped the glovebox via 2 size 30 Torx in the ceiling of the glove compartment, 2 size 30 Torx underneath the glove box on both nearside ends and 1 size 30 Torx on the right end (U.S. left hand drive) underneath the dash end cap. Then disconnected the glove box light and un-clipped a wire from some framing so as to lay the glove box in the passenger footwell. For a geezer with semi-arthritic hands, unscrewing the module (2 small phillips head) was not a piece of cake. One screw is awkwardly located behind the HVAC footwell vent. Please advise if I approached that bassackwards! I'm disinclined to do it the easy, elegant way.)
Thank you for your input. I noticed there's some relevant information on your Gremlins Never Let Me Down... thread. I may return the new module if the old does not prove defective. And please post the rockauto number for the less expensive part.
I procrastinated this small project til it was 93 in the shade. My motto's carpe diem, manana.
(I removed the glove box via 5 Torx #30 bolts: 2 inside ceiling, 2 under box on each end and 1 underneath the dash end cap. Disconnected a couple of wires connected to the glove box and laid it on the floor. Two phillips screws hold the module. One's not particularly easy to access. There may be a better way.)
Please post the less expensive part #. Thanks for your info.
Thanks. I may have posted prematurely. The module I pulled out is Denso 077800-0901. When replaced with 077800-1020 it still didn't blow. I'm taking it to local auto electric/onic shop for testing. My attempt at DIY has apparently exceeded my competence as a driveway hack.
The following 2 users liked this post by 07XKJaguar:
FrickenJag (07-27-2015),
GreyXK (07-15-2014)
I read this thread with dismay because I sourced an original Jaguar part C2Z6538 and in the box was the black Denso 077800-1020 resistor, not the previous grey 077800-0901 module that had failed.
However, to my surprise, it worked!
The blower motor is the Bosch part.
Happy days
Happy days
![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
0778001020, 2007, ac, blower, blower module, blower motor, blower resistor, c2z6538, control, denso, jaguar, module, motor, working, xk, xkr
