I do it all the time...
The convertible rear window, that is.
As you can see, I did it last night. My garage ceiling is too low to raise the top, and it had started raining. So I raised it outside (manually raised the windows)... ran upstairs with groceries... and promptly forgot about it.
If you get a little impatient with the process it's actually easy to do.
I'm missing something here .Usually the door windows close after the side windows close so how did you close the door windows. So far I haven't done what you have experienced so I just was interested in how you do this. I usually close the top in my garage but the normal cycle won't let me do what happened here.
Received 2,048 Likes
I’m guessing he doesn’t have Steve’s (aka WhiteXKR, aka theJagWrangler) remote top control, so he holds the button until the top closes and latches, then releases the button before the windows close, and then manually raises the front windows.
Get theJagWrangler.com remote top control (with rear window control is a great option), and you won’t have this problem anymore.
If you want the back windows down AND the top still up, begin the Top Down sequence and as soon as the rear windows are full down, STOP the procedure.
Pull the door seal rubber out at the bottom of the window, remove the bolt and slide the glass forward out of the window seal. It's actually kind of neat looking. Pity that the coupe glass doesn't lower since the our chassis have the vert top framework behind the side trim.
80sRule (05-29-2019)
All you need to do is tap the top button for a second and the rear windows go down with the top up. No need to start the top down cycle.
Course, THREE taps on the PAX window switch and the rear windows go down, so there's that...
