I got my wheel spacers today!!!
On other vehicles a spacer CAN affect in a much more dramatic fashion and ruin bearings. Those vehicles usually have a negative offset PLUS spacers and put therefore put load on the bearings INSIDE the barrel of the wheel. Not a good situation.
"C'est vrai, dans la plupart des cas. Cependant, les XK ont un décalage si important que même avec une entretoise, la zone de roulement reste dans le corps de la roue.Sur d'autres véhicules, une entretoise PEUT affecter de manière beaucoup plus dramatique et ruiner les roulements. Ces véhicules ont généralement des entretoises offset plus négatives et mettent donc une charge sur les roulements à l’intérieur du corps de la roue. Pas une bonne situation."
Thank's for response. The must is 20 mm front and 15mm rear ?
it's not necessary make wheel alignment ?
I'm interesting by this kit -> Wheel spacers
What do you think about this kit ? It's good ?
So... the 20mm spacers on the rear turned out to be slightly too wide. Every once in a while I would hit a particularly bad dip and one of the rear tires would rub the fender liner. I put up with it for a couple of months, but I finally realized I needed to swap out the 20mm spacers for 15mm spacers, which I did last weekend.
If anyone wants my 20mm spacers, which are good for the front wheels, just send me a PM. I'm not giving them away, but I'll sell them cheap.
well since I put on my GT 5 spokes I didn’t need my 15mm spacers for the rears, so I have a set that I would sell... So long story short if someone wanted Sam’s 20’s and my 15’s they could have a full set for their ride....
Reverend Sam (10-19-2019)
#28
burmaz
07-01-2013 06:59 PM
Sentinelist
02-20-2013 10:29 AM
