I have Jaguar XKR v8 supercharged 2011 not startimg
The correct forum for posting questions for your vehicle is the X150 forum.
https://www.jaguarforums.com/forum/xk-xkr-x150-33/
The problem your having is most likely due to a LOW/WEAK battery. Give it a good charging and then reconnect.
ANYWAY, the 2006+ X150 XK/Rs are very sensitive to Low Voltage situations.
What you will need to do is disconnect the negative battery lead and charge the battery with a GOOD battery charger for a full 24 hours. "Good" charger means a full-size one capable of at least 10 amps charging power, and that will vary the charge current and complete when the battery is full. Once done charging, the battery should have and maintain at least 12.6 Volts. If it is below that, you will need a replacement battery. If you DO get a new battery, CHARGE it fully BEFORE you install into the car, again, for 24 hours.
That SHOULD fix what ails ya.
A good number of X150 owners use a Battery Maintainer since these cars are usually driven a bit less than daily. Most of the time the maintainer is a CTEK brand. It will keep your battery up-to-snuff regardless of how long it is parked.
I've moved your question from X100 (1996-2006) to X150 (2006-2014)forum. This is the place to post technical questions about your model.
Received 2,646 Likes
acepanz2011
06-06-2017 09:11 PM
XJsc-guy
06-14-2015 03:49 PM
Global Autosports
VENDOR 'For Sale' Classifieds
11-15-2012 02:16 AM
