I need help with Instructions for hard reset.
Remove both battery cables from the battery. Touch the cables together for several seconds being completely assured that neither cable touches the battery posts! Cover the battery top with a non-metallic shield if you feel uncomfortable. Reinstall the cables from where you removed them. Reset the window operation.
That is all.
It's really very easy, just make sure the battery is totally out of the circuit.
That is all.
ralphwg (07-08-2021)
Cee Jay (07-08-2021)
Received 1,123 Likes
JagV8 (07-09-2021)
I have gotten quite good at the hard reset. I have to do it every time...and I do mean EVERY STINKING TIME I clear the codes...because...the car won't start.
Surely there is an independent mechanic in Chicago that will take my car and do some sorcery to it. I just have to find them.
I will give you $5k for it, right now.
I drove to work today and man was it a glorious cruise. Love downshifting while driving through various under-bridges.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Without doing a hard reset, when you try to start does it crank?
Any flagged OBD codes?
What pending OBD codes?
To your first question, after I reset (erase) the codes using Autel AP200 and turn the car off...when I go to try and restart the Start/Stop button will not light up/engage. Some lights will flicker (warning, I forget which ones but one is to lower and to the right of the round fan dial on the infotainment) and a loud series of clicks from the relays occur.
Will try and replicate and respond later. Thanks for asking.
I would think this the obvious question: Why continue to use the ODBII tool that is clearly incompatible with this system? Why gamble on the car being absolutely bricked? Please don’t misinterpret me… I wish you all the luck and success. And I do hope a dire situation does not fall upon you.
ralphwg (07-10-2021)
