If the bonnet cable snaps?!?
When I was sorting my electrical issues I had to undo bonnet mechanisms etc, and forgot to put one of them back together properly. We were lucky, the other one wasn't connected and the nose was off so we were able to disconnect the bonnet at the front - and really wrench the cable to pop open the bonnet.
Made me think - years down the line, what happens if a cable snaps? I can't see any way in without cutting the bonnet where the pieces the connectors latch onto are, and remove. Anyone know of any other way into the bonnet?
I do not have a solution to your problem, but perhaps an idea that will help.
On TR6 cars, this was a big issue as the hood cable was prone to breakage.
Owners drilled a very small hole in the cowl on the passenger side above the foot rest, and fed a thin wire through to the hood (bonnet) latch.
Not the most convenient, but in a pinch, you could access and pull the wire from the passenger side to open the hood.
Lots of info about this by searching on "The Triumph Experince" website.
Bob
Bob
Bob
Bob
In all the cars I have owned (in my younger days older used cars that I drove into the ground), or anyone I have known who owns cars, this has never been a problem and every one of them had a passenger compartment release latch with cable. Talk about preparing for the most obscure of issues! Only reason you had the issue this time was because of a maintenance error.
Temperature drop causing condensation to freeze raises the force required to move.
Combine this with temperature drop making steel brittle and you can have it go Snnnaaaaap.
Good point, having them on the firewall side adds a different dimension.
The fact that it does happen as you say confirms to me i should create some sort of back up - actually wouldn't be too difficult.
The mechanism itself is so simple, just need something to pull it as a backup
