Injector prices
Injector prices
A second injector has gone bad in my 2011 XK convertible, 40k miles on the clock. First one was fixed by my mechanic and the item cost about £380. I'd like to replace all of them but at that price it's a killer. He says that the high pressure Denso injector is a necessary expense. However I have seen Bosch ones on eBay at under £100 with a 5 year warranty! Are they a risky choice? What would you do? My 1998 XKR has done 90K with no injector problem! Touch Wood!!
Ernie
Gloucester.
If it ain't broke, it's just a matter of time!
Ernie
Gloucester.
Ouch on that £380, mine was like $120, so like £86 for the Denso. That's still a great expense for all eight of them. Plus, if a shop does it the full cost would be like $3500, at a dealer near $5000.
I think maybe you should shop around before you decide.
This is Rock Auto for the Bosch:
Ernold (02-28-2021)
I wasn't advising the use of Rock Auto, just demonstrating the cost. If OP can't find cheap ones anywhere, he could always get a friendly forum member to receive an order and then forward it to UK.
U.S. $72,50 at Europarts
https://www.eeuroparts.com/Parts/187...or-0261500298/
May ship to the U/K, don't know where they are...
The trouble with the injectors is it's impossible to predict IF or WHEN they will fail. Unlike say H2O2 sensors or coils which have a more finite lifespan, you may NEVER get another injector fail. On the other hand, you could replace the set and get one FAIL in only a few thousand miles.
I'd do the reseach, file the information for future reference and wait until it happens.
Rock Auto do post to the UK. I have used them myself for spark plugs and with postage was still cheaper than anywhere in the UK.
Cee Jay (03-01-2021)
JTBUU2D : Cheaper injector fitted and working perfectly. 3 coil packs had failed so he replaced the lot. Cost £500 I found some for £22 each! too late however. They can also be repaired if it's just the case leaking. Which is usually the caee. U live n learn! So total bill £1130. Could be worse.
Ernie
Gloucester. UK
Ernie
Gloucester. UK
I'm all for preventative maintenance but for me that tips over the line into expensive overkill.
I had a failing injector on my X351 5.0. Local mechanic wanted to charge me Jaguar prices ($400 each x4) for the injectors. Either he is too stupid to know it's a $80 Bosch injector, or he was going to make a cool $1300 simply ordering the parts from a different place. I did the job myself.
The following 4 users liked this post by silvertonesx24:
mystype04
07-12-2013 03:08 PM
