Inop top
I disconnected the battery to install the top remote kit. Upon completion the top would latch closed, and reopen for 6-8 " following other posts with this problem, I manually stowed the top. This had no effect on the ability of the top to do anything. I manually raised the top and disconnected the battery, waited 15 or so minutes, reconnected the battery and tried the top again, nothing. I have tried with the top up and down, disconnected the battery several times all for nothing. The battery is fully charged and I had no problems till I disconnected the battery after the installation to reset the top control.
Any ideas? I am out of them.
Received 1,975 Likes
Do the front window reset again. Then try to operate the top with the console the first time after the window reset, not the remote.
If it does not work repeat this sequence again. Keep repeating up to half a dozen times or so until the problem is solved. The window reset on the XK/XKR does not always 'take' and sometimes needs to be repeated quite a few times.
After all this if it still is not working properly contact me as suggested for further help.
-Steve
-Steve
Go to my contact page and lets set up a mutually convenient time to do a phone call with you at the vehicle: Contact Us - TheJagWrangler
It is important to me that all of my customers successfully install the kit.
Cee Jay (06-27-2019)
mitch.thompson
01-19-2011 02:13 PM
satrianirocks
10-28-2009 09:09 AM
