Installing Dead Pedal in XKR
I have received a new Dead Pedal for my 2009 XKR.
Does anyone know if its safe to drill into the floor area where the dead pedal goes without hittting any wiring or fluid tubing lines.
I plan to use self tapping screws to hold it down #10 head & 1/2 or 3/4" long. Drill hole will be 1/8" in diameter.
Please advise if you can help.
MaximA (02-27-2014)
No screws came with the dead pedal from Ultimate pedals, but that is no big deal. I have a Home Depot and Lowes close by to buy self tapping screws.
I just want to make 100% sure there is nothing in the way in the undercarriage when I go to drill into and though the floor board.
How hard was it drilling into the upper hole?
As I place the dead pedal in position, it doesn't look like there is much room for a drill to even drill the hole. The bottom hole looks like no problem.
I would also like to replace the chrome on the brake and gas pedals. Any suggestions where I might to buy just the crome trim pieces?
Richard,
I didn't drill starter holes. The self-tapping screws went in easily with a big handled short screwdriver that gave me enough leverage to do so.
The only source for the OEM gas and brake pedal covers that I'm aware of is Jaguar parts department at a dealer. I'm surprised you need new ones with such low mileage on your car. Did they get damaged? They still look good on my car with over 32k miles.
The OEM pedal covers are polished stainless steel, not chrome. The Ultimate Pedals
footrest is milled aluminum. The difference in finishes is noticeable, but doesn't bother me.
Stuart
Stuart
richzak (09-08-2013)
Richard,
Stuart
Stuart
As for the metal portion of the brake and gas pedal, mine have some marks and scratches on them nothing major, no major damages, and saw they are secured with an allen wrench nut and wanted to replace them. However as you stated they are different metals. They are not damaged, just scared a little. I wanted all pedals to look brand new.
Thanks so much for the input, it gives me a better idea of your installation. I made contact yesterday with another member who actually drilled into the floorboard to secure the dead pedal with screws.
The footrest area of the floor is molded up from the metal floor with lots of free space between the footrest carpet surface to the metal floor--6 to 8 inches or so. No need to drill a hole into compressed formed cardboard. Simply line up your foot rest plate and screw it in; nothing to damage in the space under the formed raised area, just air.
... As for the metal portion of the brake and gas pedal, mine have some marks and scratches on them nothing major, no major damages, and saw they are secured with an allen wrench nut and wanted to replace them. However as you stated they are different metals. They are not damaged, just scared a little. I wanted all pedals to look brand new.
You should be able to polish out most, if not all, of the scratches from the stainless steel pedal covers with a Dremel tool and jeweler's rouge or similar metal polishing compound.
I know she's your baby, but it's OK when they get older and get a few zits. You'll still love her!
Stuart
Got the footrest installed and as DGL noted above, there was no aluminum floorboard or bulkhead to drill thru. The surface under the carpet was relatively soft and easy to put a #10 x 1" stainless steel screw into the material. I backed up the rigidity of the dead pedal with industrial strength velco and the dead pedal won't move even if the screws do come loose.
Yes Stuart, your right. The XKR is such a great car. I love driving it. It is a great ride and runs so smooth. Handling is excellent, and it's fast, so what isn't excellent about our cars. I am very well pleased with the XKR, and even though I have the 2014 Porsche 981, there is a difference in the drive between the 2.
I have a great choice every day I want to drive one of these premium automobiles.
Good idea! Wish I had thought of that before I installed mine. I'll keep it in mind if mine comes loose and I have to reinstall it.
I buy the Velcro in industrial strength adhesive rolls that are 4" wide and about 20 feet long. In the case of the dead pedal, I took the Velcro and completely covered the entire back of the dead pedal with the hook velcro and the loop velcro applied to the hook then pressed hard against carpet area. The industrial strength adhesive is very strong. It will not move. The screws were placed into the dead pedal to complete a finished look, but the screws were not really necessary.
sherbercars (02-27-2014)
The following 2 users liked this post by Schwabe:
MaximA (02-27-2014),
If your going to use it for a dead pedal installation, just send me a private email with your real name and address and I will send you 10" of the 4" wide female and male (Hook & Loop) industrial strength Velcro.
Then you can simply lay the dead pedal over the Velcro and cut it to the size of the dead pedal and go from there.
Just don't peel off the white backing until your ready to use, otherwise what ever it sticks to it will be very hard to pull off. It has a strong adhesive.
No sense in buying and paying shipping when I can mail 10" to you for $1.00 postage.
You owe me nothing. Glad to help you out if you want to take me up on the offer.
Thanks for the offer.....if I buy new ones, I will just send you the old. They are a bit scruffed up however. Not too bad but not yet needed to be replaced at this time.
I will remember your offer and let you know if I am going to make a change. I already have your address from the Jaguar leaper badge I sent to you.
Hopefully that worked out well, except for the snail mail to Canada. I am sure it looks great on the rear end of the Jag.
Would you share the source and costs for the dead pedal? Thanks.
Albert:
$130.00 custom made for the Jaguar XKR model. 2 weeks turnaround time from date of order. Sent via UPS to you.
Vendor was:
Ultimate Pedals
(561)798-6588 or sales@ultimatepedals.com
Ask for Robert...He is familar with the Jaguar XKR dead pedal.
Hope this helps.
Vendor was:
Ultimate Pedals
Hope this helps.
axr6 (02-27-2014)
Syd:
