Instrument Cluster Lights
I noticed today that the center section of my instrument cluster wasn’t illuminated. It’s the section with the clock, fuel gauge, mileage. After about 10 miles, I noticed that it was illuminated as normal. I made a couple of stops and all was normal, then on my way home it darkened again. When it’s not illuminated you can see it, but it’s sort of “grayed out”. I have a 2 month old AGM battery and use my CTEK each night. Search didn’t help. Ideas?
No, definitely not plug & play, and even if you do get it programmed to your car it will still show the VIN and mileage of the donor.
I think someone with some electronics repair know-how would be able to check the LCD and clean / re-do the ribbon cable connections to the screen itself.
Or in the worst case replacing the screen would be possible, if a spare unit could be located.
I seem to recall someone already looked into this, I can't remember where I saw it though...
arenaej (02-06-2019)
I missed the mention of the battery. Why did you put an AGM in this car? It's not meant to have one.... AGM's should only be used in cars where an AGM is the original fitment.
AGM batteries require a different charging method than a conventional lead acid battery, the alternator in the XK is designed to charge a regular lead acid battery, it will overcharge an AGM.
Conversely I have seen some crazy stuff happen to the electronics in cars when an AGM was fitted in place of a standard lead acid battery, after putting the correct battery in the car, everything went back to normal.
It's a common misconception that AGM is better. No! it's only better if the electrical system in the car was designed for it.
guy (02-07-2019)
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
I just did another search and found the answer. Cambo, you are correct. The center lcd connects with a ribbon cable. Replacement is possible. Since it’s working and still visible even when it’s dim I think i’ll live with it for now.
Stuart, My CTEK is set to winter mode always. Thanks.
I found a local repair shop for the instrument cluster:
Powls Speedometer Repair
717-898-2552
If I bring them the cluster it’s $250-$450 plus parts. They have done them before. It may just be the cable, the LCD or a main board repair. They won’t know until they see it. Seems much cheaper than a new cluster. From what I’m seeing here, by the time I remove the cluster it’s not brain surgery to replace the LCD or cable , or both. To quote Ranchero50 on another thread, I’ll “put up with it until I can’t”.
On the AGM battery part of this discussion, I went back to see what I looked at when making that choice. I considered it first because I saw some on this forum with 2007-2009 XK’s that have used them without incident. I see many sources that, when comparing AGM to wet cell say that in vehicles with lot’s of electronics and accessories and vehicles that don’t see regular use (that’s mine), AGM is a viable choice when paired with the proper maintainer. After Re-reading everything, I would make the same choice. I do appreciate the knowledge and opinions expressed here.
717-898-2552
Here's a whole assembly if you want to go silver faced gauges. Their not too difficult to swap out. Truth in advertising they aren't that great at dusk because the back light makes the numbers disappear.
https://www.ebay.com/itm/2009-Jaguar...3zU:rk:12:pf:0
arenaej (02-07-2019)
Here’s a link to the center lcd screen on eBay. It’s new, labeled for XF, but thanks to Ranchero50 we know that it will also fit the XK.
https://www.ebay.com/itm/Color-LCD-d...53.m2749.l2649
Queen and Country (02-08-2019)
Wow $40 for an instrument cluster.
This is where owing a Jaguar pays off.
Look what it is for the Aston. $1000, and only one available worldwide. Grand for the Maserati too.
https://www.ebay.com/itm/Speedometer...frcectupt=true
https://www.ebay.com/itm/Speedometer....c100752.m1982
The following 2 users liked this post by shemp:
Queen and Country (02-08-2019),
Sean W (02-08-2019)
Here’s an update on my instrument cluster display. I decided to do a hard reset as an experiment, so disconnected the battery cables and touched them together for a minute. Re-set the e-brake, windows, etc. The center display was illuminated when I started the car. Ran a bunch of errands, stop and start 5 or 6 times over 35 miles of driving. It stayed illuminated the whole time. Hopefully that’s it. I did order the replacement I found on eBay. It’s on a slow boat from China.
Received 1,123 Likes
