Interior Veneer Trim - remove & refit
Old 04-04-2021 | 06:47 AM
Default Interior Veneer Trim - remove & refit
JLR last published the Interior Veneer Trim removal and refitting instructions (C2P18926/27/28/29/30/31) in 2010.
The PDF is too big to post on the forums as an attachment so I've added the pages here as individual graphics.
The instructions are specifically for the earlier 4.2 but the procedures apply equally to the later 5.0 models.
The following 12 users liked this post by GGG:
Boga (04-04-2021), guy (04-06-2022), JonWat (11-25-2021), Kizik (04-08-2021), kj07xk (04-04-2021), LockNumber25 (04-04-2021), peterv8 (04-05-2021), Sean W (04-04-2021), steve_k_xk (11-23-2021), Stuart S (04-06-2022), tmich (04-04-2021), V7Sport (04-04-2021) and 7 others liked this post. (Show less...)
Old 04-04-2021 | 09:14 AM
kj07xk's Avatar
Don’t you just love that the instructions show that you should toss the old ones in the trash?
The following 6 users liked this post by kj07xk:
Boga (04-04-2021), guy (04-04-2021), JonWat (11-25-2021), peterv8 (04-05-2021), Sean W (11-23-2021), steve_k_xk (11-23-2021) and 1 others liked this post. (Show less...)
Old 11-23-2021 | 03:30 PM
DorsetJag's Avatar
Is that because the removal damages the parts beyond reuse? Has anyone successfully removed and refitted the trim pieces?
Old 11-23-2021 | 04:06 PM
scjordan1969's Avatar
Never ever damaged mine? changed from ally/piano black to walnut, and sold my old stuff, you just must buy a plastic trim removal set, they very cheap on ebay, recently removed passenger airbag trim and drivers trim again as i wanted to replace both air vents that had discoloured wierdly, no damage 👍
Old 11-23-2021 | 04:39 PM
shemp's Avatar
I don't need to replace mine but I have an annoying buzz from vibration of the trim behind the steering wheel. Thanks for posting this. It's helpful to see how to remove it.
Old 11-23-2021 | 05:05 PM
Sean W's Avatar
well you want to know where the lift points are and yes you can break them but with a little care they come off easily. People swap the out all the time or pull them to vinyl wrap, hydrodip etc...
Old 11-24-2021 | 11:29 AM
fxdwg's Avatar
That's probably the air sensor behind the small grill. It's a common source of a buzz in that area. Try cleaning it.
Old 11-24-2021 | 01:06 PM
Sean W's Avatar
This is an old thread. Graham has since added the PDF to the DIY sticky section and you can download it here:
http://www.mediafire.com/file/g1lvpy...r_Kit.pdf/file
Old 11-24-2021 | 01:43 PM
htrdlncn's Avatar
Link doesnt work,,says:
"pdf.part could not be saved, because the source file could not be read.
Try again later, or contact the server administrator."
Old 11-24-2021 | 01:51 PM
lear60man's Avatar
How hard are these trim pieces to get from Jaguar? I really like the turned metal ones.
Old 11-24-2021 | 02:02 PM
Check your spam filter isn't blocking it. It is definitely available and working as an amazing 359 downloads confirm:
Old 11-24-2021 | 02:12 PM
htrdlncn's Avatar
even with all filters off link itself didnt work,
I just right clicked and saved it and that worked fine.
GGG (11-25-2021)
Old 04-06-2022 | 11:28 AM
BlueFox459's Avatar
Anyone have a connection with any companies that sell Veneer Kits for the X150s? Would love to remove the "Old Man Walnut" Veneers and replace with Piano Black or Carbon Fiber.
Old 04-06-2022 | 11:34 AM
htrdlncn's Avatar
pieces are easy to remove,,take them to any place that wraps cars and have them wrap them in any color youd like.
Old 04-06-2022 | 01:04 PM
guy's Avatar
guy
it seems Jaguar incorporated ‘my’ modifications to the process.
Old 04-07-2022 | 12:50 PM
lear60man's Avatar
FYI, you can get a set of knurled aluminum fro Rimmerbros for not much. I switch out my wood ones with the aluminum set just to keep things fresh. 5 minute job. When I want to class it up, I switch back.
Old 04-07-2022 | 04:18 PM
BlueFox459's Avatar
I checked them out (very nice site by the way) but $860 for a set of aluminum veneers is a bit much for me. I think I will just wrap them. Thanks!
HartellL
04-06-2021 08:27 PM
JayW
05-29-2020 08:59 AM
TexasTraveler
04-16-2018 01:02 AM
Dell Gailey
01-03-2018 02:37 AM
HarpersMuse
XJ40 ( XJ81 )
26
08-03-2017 01:35 PM
Quick Reply: Interior Veneer Trim - remove & refit
