iPhone 6 connectivity issue 2011 XK
iPhone 6 connectivity issue 2011 XKR
Recently the iPod port through the supplied cable with lightning adapter stopped working properly. The vehicle will see the phone device, but will only play for a second then stop. When I hit the play button, it begins to play then stops immediately. Any advice out there?
I realize the later models will play via Bluetooth, but the 2011 needs this cable.
Check the other end of the cable where it plugs into the car, too. It may also be worth going to a dealer & see if you can try another cable - one or two people have had issues with the cable. That may be because it's so stiff and inflexible that it can get bent in odd ways, leading to breaks in the conductors.
Here's an idea instead of having to plug in your phone every time you get into your car, then UNplugging it when you leave... Get an appropriately sized flash drive and put ALL your music on it. Stick the flash drive into the USB port right next to the iphone port and Leave it there. No cables, no connecting problems, just all your music all the time. I have nearly 9000 songs on mine, about 38 GBs in size.
ralphwg (07-08-2015)
Cee Jay (07-09-2015)
I came to the Forum today specifically to check if anyone knows of a fix for this. I have an iPhone 6 Plus and a 2013 XKR and cant get my music on my phone to work through tune2air or direct cable into iPod port. Same 1 second playback to pause situation everyone else has. It's driving me bonkers having to listen to the F0CKlNG radio!
ralphwg (07-21-2015)
