iPhone 6 connectivity issue 2011 XK
Old 03-29-2015, 07:48 AM
vacolorito's Avatar
Default iPhone 6 connectivity issue 2011 XKR
Recently the iPod port through the supplied cable with lightning adapter stopped working properly. The vehicle will see the phone device, but will only play for a second then stop. When I hit the play button, it begins to play then stops immediately. Any advice out there?
I realize the later models will play via Bluetooth, but the 2011 needs this cable.
Old 03-29-2015, 09:34 AM
Jhuntbatch's Avatar
chances are the cable going into the phone may look like it's connected fully but is only inserted about 90%. I would pull the cable and re insert it into the phone, it should fix the problem immediately.
Old 03-29-2015, 06:22 PM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
Check the other end of the cable where it plugs into the car, too. It may also be worth going to a dealer & see if you can try another cable - one or two people have had issues with the cable. That may be because it's so stiff and inflexible that it can get bent in odd ways, leading to breaks in the conductors.
Old 05-13-2015, 03:08 PM
vacolorito's Avatar
jaguar dealer service told me the iPhone 6 is not compatible with the supplied cable on the 2011 XKR. Some connectivity issue that Jag issued a bulletin to dealers on.
Anyone else been able to get their iPhone to work in a 2011 with the cable for iPad?
Old 05-14-2015, 06:09 AM
Ngarara's Avatar
Mine is a MY11 (sold late 2010) - it works fine with my iPhone 6 using a Jag cable and Apple Lightning adapter. I cannot guarantee that it's the original cable, though; I'll try to remember to check if there's a part number on it when I'm next in the car.
Old 05-20-2015, 04:44 AM
vacolorito's Avatar
I bought the tune2air and the same issue. the phone music apps will only play for less than a second then go to pause.....
this is frustrating.
Old 05-20-2015, 04:48 AM
Ngarara's Avatar
Just a thought - what iOS version are you running? I'm still on 8.2, keep forgetting to upgrade. Maybe 8.3 causes the problem...
Old 05-21-2015, 05:22 AM
vacolorito's Avatar
i have ios 8.3 so maybe that's the problem.
how do you restore a previous ios?
Old 05-21-2015, 07:24 AM
Ngarara's Avatar
I'm not sure, never had to do it - I suspect Google is your friend for that.
Old 05-21-2015, 11:15 AM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
Here's an idea instead of having to plug in your phone every time you get into your car, then UNplugging it when you leave... Get an appropriately sized flash drive and put ALL your music on it. Stick the flash drive into the USB port right next to the iphone port and Leave it there. No cables, no connecting problems, just all your music all the time. I have nearly 9000 songs on mine, about 38 GBs in size.
Old 05-21-2015, 04:01 PM
bocatrip's Avatar
My iphone 6 used to work with Ios8.2 and not 8.3. for my music. My flashdrive works intermittently.
Old 07-08-2015, 02:36 PM
vacolorito's Avatar
just updated to iOS 8.4, still not working. upon starting to play, music will go into pause mode almost immediately. Anyone out there have any idea for a solution. My local dealer is of no help.
Old 07-08-2015, 05:37 PM
Cee Jay's Avatar
The only option to make an iphone pair correctly every time is to throw it in the trash and buy pretty much ANY Android phone. All my Androids have paired perfectly, and the daughter's iphone just won't pair, ever (No, she can't DRIVE the car, borrowed her phone to check).
ralphwg (07-08-2015)
Old 07-08-2015, 05:51 PM
ralphwg's Avatar
Received 1,211 Likes on 917 Posts
Cee Jay (07-09-2015)
Old 07-14-2015, 01:28 PM
Supreme Machine's Avatar
I came to the Forum today specifically to check if anyone knows of a fix for this. I have an iPhone 6 Plus and a 2013 XKR and cant get my music on my phone to work through tune2air or direct cable into iPod port. Same 1 second playback to pause situation everyone else has. It's driving me bonkers having to listen to the F0CKlNG radio!
Old 07-14-2015, 05:32 PM
Ngarara's Avatar
I have a 6 on iOS 8.3 that's fine, but my car is a MY11. You could try a reset of the iPod interface module (pull & replace Fuse 24 in the rear-seat fusebox) and the audio system (Fuse 21, same place)
Old 07-20-2015, 04:19 PM
Still no dice for me and my iPhone 6 Plus. Tried pulling and replacing the two fuses, still the same result. I even went the lengths to update my iPhone to a beta version of iOS 9, still the same result.
This is getting annoying to say the least.
Old 07-21-2015, 02:15 AM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
The fix is to pester Apple until they make their gadgets work.
ralphwg (07-21-2015)
Old 07-21-2015, 11:40 AM
Cee Jay's Avatar
The trick is to NOT BUY Apple products since they DON'T work.
Old 07-21-2015, 01:41 PM
JagV8's Avatar
Er, I suppose that's another fix but a mite unattractive for some.
Quick Reply: iPhone 6 connectivity issue 2011 XK
