Issue starting ... brake pedal
Starting the 2007 XKR occasionally I get a lot of brake pedal and the car won't start. Second or third time the pedal seems to give a bit and the car starts fine. I'd be fine overriding the brake to start ... but I'd rather it worked as it should ... I have a new AGM battery it is certainly not a battery cranking problem ... there's enough juice now to crank the motor for a WWII fighter plain, some gremlin to deal with the brake, the safety switch, something ... any thoughts?
If you inadvertently pump the brake pedal, it will feel high and rock hard. The high pedal makes it difficult to make contact with the starter switch, so you'll have to stand on the brake pedal with both feet when you press the start button.
The simple solution is to press the START button BEFORE you step on the brake pedal.
Note that other manufacturers require that you step on the brake pedal before you press the start button. Jaguar works either way, but I find that my car starts much quicker when I press the start button before stepping on the brake pedal.
My Jaguar service adviser recommended this, notwithstanding the Owner's Handbook to the contrary.
Received 1,975 Likes
High and rock hard ... I remember those days ... I digress, I've always turned the vehicle on and let the fuel pump run before engaging the starter ... I had a 2011 5.0 XKR and an 2007 ragtop, did not exhibit this issue. Yesterday I actually got out of the car and started anew, as I had tried a good five or six times to get the vehicle started ... been running it hard with the dense cool air we've had here in Ohio ... thought maybe it was reluctant to go out and get thrashed about ... 🤣
It's a quirk ... I'd rather have it right, but every Jaguar I've owned has been quirky ...
Thanks!
Thanks!
ejp (01-13-2022)
DB6
06-21-2011 11:21 AM
